Question about IBM TravelStar 40GN 40 GB Hard Drive
Ibm Travelstar usb 2.0
I have had the ibm Travel star usb 2.0 for around 12 months and it has worked well. When I plug the hard drive into my pc now it dose not connect, the light stays green. I have tryed it on other pcs and different usb ports but still nothing. Can you help as I have over 4000 photos on it.
Thanks
Martin
  • 3 more comments
  • yun_nan Jul 19, 2008
    Hi, Martin,
    I have exactly the same product and same problem. Have you got any help from others now?
    Thanks
    Daniel
  • fluggin Jul 19, 2008
    Hi Daniel
    No Not as yet, I just hope I Can get the photos off it!
    Thanks
    Martin
  • Gards Dec 14, 2008
    I have the same problem aswell. Did you end up figuring it out?
    Wes
  • max12748 Jan 26, 2009
    Hello, I have the same problem. Powers up but does not detect the harddrive.
  • akshitsingla Mar 09, 2009
    not happy enuf wid the solution sir..
    Problem Solver:
  • 14 Answers
I assume you can't see it in Windows? When you connect it can you hear the drive spin up? If not then there is a hardware problem - motor failure, jammed platter. If you hear it clicking or clunking then it is likely to be a stuck head or actuator. If so sometimes you can give the drive a sharp **** to and fro to try and spin the platter - don't do to long though. If this doesn't work then you would need the data removed by a data retrieval company.
If the drive does spin freely you may be able to fix by doing in order:
running check disk (properties of drive then tools)
using a data recovery program of which there are a few
using commercial data retrieval company.
Hope this helps
Posted on Jul 30, 2008
SOURCE:
I need a new a new cable (fits an unusual 5-pin socket) for an ibm travelstar external hard drive
the dearlership should know what you need. the reason the socket is so different is to let you know, the stuff in which contained in this part is very sensitive and could major problems if you are not sure what your doing
Apr 13, 2012 | IBM TravelStar 40GN 20 GB Hard Drive
Hi, I have one IBM Travelstar USB 2.0 external hard, suddenly now it is not deducting and the light which is there in USB device, some time it is green and red alternatively.. Pls help to resolve this...
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jun 06, 2011 | IBM TravelStar 40GN 40 GB Hard Drive
Hello, quick question: I have a totally broken IBM laptop, and I've removed the hard drive, which is a 40GB Hitachi Travelstar 5400RPM ATA/IDE: Exact model#: HTS541040G9AT00 I'd like to copy the...
Yes! There is such an adapter. Look here for IDE/SATA to USB: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770
Obviously, you don't have to buy this product or buy from Tiger Direct; this is just an example of the type of product you're looking for.
If you're comfortable working inside your desktop, then you should check out this product which is much cheaper: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329310&CatId=3770
Good luck and thanks for using FixYa.
Mar 16, 2011 | Hitachi Travelstar 5K100 HTS541040G9AT00...
Unable to download folders (photos, personal documents, etc) from 5 y/o Pentium PC to IBM TravelStar 2.0 USB External Hard Drive with following message appearing... "Cannot create and replace (folder)...
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Dec 11, 2010 | IBM TravelStar 40GN 40 GB Hard Drive
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
How much could i sell my Travel star tm. usb 2.0 for? and were?
Not much, if it is used. Dell had trouble with those in the inspiron notebooks, and they are replacing them with western digital. I did some checking you are lucky to get $5.00. I would try to sell it at ebay.
Aug 13, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Getting files off an old IBM TravelStar 20 GB Hard Drive
You can buy an adaptor that will connect your hard drive to a pc.
Ribbon cable from your secondary drive on pc goes into the adapator. Adaptor also coonects to laptop harddrive.
You also need to change from being a master driveto be a slave drive . see linkbelow.
http://www.hgst.com/hdd/support/tva/tvajum.htm
You can then copy file to pc a usb memory stick.
Oct 13, 2008 | IBM TravelStar 40GN 40 GB Hard Drive
Dell laptop with no cdrom and travelstar HDD
In this case you would have to...
1) preformat the drive
2) make it bootable in DOS
3) copy the CD contents to the drive
4) boot the target computer with the drive and run WINNT.EXE in the I386 directory to start the install.
*OR*
2) copy the CD contents to the drive.
3) put the drive in the target computer and boot it from a DOS bootable floppy.
4) run WINNT.EXE in the I386 directory to start the install.
Jun 26, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
Cannot Open when connected
I connect harddrive IBM Travelstar 20 GB Model IC25N020ATCS04-0 (made in Thailand) to PC via USB port but cannot open ,LED is light .How can I do , I have no driver.Pls. help me.
Jun 01, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
IBM TravelStar 40GN 40 GB Hard Drive Logo
1,968 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
