A wire/plug is needed. - Computers & Internet
    Problem Solver:
  • 7 Answers
Not enought info. That's like saying I need a key for a car.
Posted on Jul 16, 2008
Spark plug wiring diagram for a 2003 chevy malibu
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
What do I need to do to change spark plugs and wires on 1997 mountaineer
Spark plug wires just pull off and press back on. Make sure you grasp the wires by the rubber boot only. If you pull the wires by the wires, instead of using the boot, you can break the wires. Remove the plugs with a 3/8" ratchet, extension and a spark plug socket. I do not know if you have to remove anything to get access to the spark plugs and spark plug wires. You may need a universal joint to angle the ratchet.
May 15, 2014 | 1997 Mercury Mountaineer
Steps to change a spark plug
easy job replace one spark plug at a need buy new set of spark plug wires and spark plugs.reason need new wires possible old ones will break from inside plug boot when you remove plug need basic 3/8 ratchet need long short extensions.need spark plug socket.need spark plug gap gauge.need a universal joint connect to the extensions to reach sharp angles.make sure engine cold when replacing spark plugs could damage heads.use a 12 inch piece vacuum hose to help aid in installing sparks in hard reach spaces with out damaging crosss threading plugs threads and cylinder head threads to plug.
Apr 25, 2013 | 1998 Pontiac Grand Prix
I need to change the plug in my dryer and i dont know how to attach my new 4 wire plug. my last plug was a 3 wire plug. i have a new kenmore dryer and my old house allowed me to use a 3 wire but my new...
You'll have to lengthen the wire. You should be able to lengthen it by cutting the terminal off the end of the wire and stripping it. Then attach a piece of wire to it with a wire nut. If you use solid wire you shouldn't need a terminal -- just bend it into a circle.
Nov 17, 2009 | Kenmore Elite HE4 Electric Dryer
Replace spark plugs and wires
ive found easiest access is to lower inner fender walls and change plugs from there
Nov 07, 2009 | 2000 GMC Yukon XL
I just bought a used amana dryer that is 1 year old. it has a 3 wire pigtail and i have a 4 wire plug in and need to change out the pigtail. need some direction on if possible to change it out or will i...
go to the local hardware store and buy the male plug for the female plug that you have in the wall just hook up the three plugh in place of the 4 wire plug. The 4 wire has a netural and a ground which is the same thing and two 110 hot wires that are 110 v each, hook up the copper colored wires to the copper colered wires and the one ground on silver. screw or white to silver wire. this is Ground you only need one ground and if the plug on the wall is three prong it is go to use a three wire plug the third wire is for a backup ground on new systems
Oct 04, 2009 | Amana NDE2330AY Electric Dryer
Wire broken near plug. Need disassemble a plug. How
You can buy a new plug and solder the wires to it. Leave a long enough piece of wire on the old plug to test to see which wire goes where. On the plug it should be tip+left, 2nd ring + right and the base or body is ground. Don't forget to put the shield that screws on the plug right way around on the cable before you solder.
Aug 12, 2009 | Skull Candy Full Metal Jacket Stereo Ear...
Need to replace spark plugs and wires on 1996 mercury sable but need simple instructions. first time doing it. i have no money to pay someone to do it but it's needed badly.
simple do it one at a time unhook the plug from the wire and the coill pack using a 5/8 spark plug socket remove and replace plug then replace wire. Move to next wire
Apr 26, 2009 | 1996 Mercury Sable
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
