Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
KP-53HS30-Picture is dark
Our picture is dark. Tried all suggestions from manual and Sony Support.
Sony support says it could be a lamp needs replaced. Our manual doesn't show the location of a bulb.
Help?
Jane
  • jayandjane Jul 17, 2008
    Our latest reply from Sony is that the TV doesn't have a bulb which is replaceable by the user.
  • jayandjane Jul 18, 2008
    We wiped them off - didn't look dirty - what do you suggest we use to clean them?
Clean off the projector lights
Posted on Jul 18, 2008
I recently bought a Sony KP-53HS30 rear video TV
Hello Sarah!
There is no bulb to replace in your TV. Image is created by three CRT's and you don't want to replace them, just trust me on that one. It could cost you up to $1800 to do that.
All you can do is to clean lenses of those CRT's. You have to disconnect TV from the power outlet and remove rear cover. Using very soft brush and vacuum cleaner remove dust from Red, Green and Blue CRT lenses. Do not use solutions unless you got something special for optics. Solutions will leave film on the surfaces. That would improve brightness and contrast of image.
To adjust focus front grille have to be removed. Than central piece cover held by 5 screws. Behind it you can locate black plastic "box" size little smaller than cigarette pack. there are 6 adjustment "screws". Three of them are "screen". You don't touch those. Another three "focus" there is one for each color. Turn TV on. Hit "menu" button. And adjust focus for each color separately. If menu goes away hit it again.
This is the only improvements you can do.
Everything else will involve humongous amounts of cash.
Russ.
Apr 04, 2010 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
I have problems with my convergence, the picture shows on a oval shape. Its a Sony KP-53HS30
You need to replace two convergence out ICs STK392-560 in D board of TV.
Above said ICs are available in Parts Store.
Apr 21, 2009 | Sony KP-53HS30 53" Rear Projection...
Sony projection tv kp-53hs30 made nov.2003
do you think you can take a picture and send it to this website
Aug 08, 2008 | Sony KP-53HS30 53" Rear Projection...
KP-53hs30 7 Blinks
Q8035 or Q8038 are shorted on the D board
Jun 02, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30
Yesterday I got the same with RED color.
I guess ptoblem is with Hi voltage multyply HVB-1031//x.
Not sure yet... still looking for info
May 02, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30
sent the info to your email address
Mar 31, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53
I just sent you the requested info to your email
Double images--3d view--ghost picture Sony KP-53HS30
The convergence amps are the big STK's*** located possibly on the G-board in the sony. It is very difficult if you are not familiar with components and soldering, You can buy them at MCMelectronics, bluestar-online.com, Tritronics, VanceBaldwin.com, etc. Diagrams are online at fixya.com on the rightside of screen. Places like Manual.com or you can search the web. Hope this helps!
Sep 24, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
185 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
