It says windows has detected a problem and has shutdown to prevent damage. I have done all the steps but is not working. Please help me!
Help me
Posted on Jul 16, 2008
'' a problem has been detected and windows has shutdown to prevent damage''
From the description it is the hard drive that is the problem, format the whole hardware and re-install your xp windows to see if that will clear up the problem, if not! have the hard drive tested to see if it must be replaced.
May 02, 2012 | HP Pavilion dv4000 Notebook
Tip
A problem has been detected and windows has been shutdown to prevent damage to...
Blue Screen Of Death (BSOD) Important Info
When you get a Blue Screen Of Death (BSOD) on your computer this can be very frustrating. Below is the info you need to get from a BSOD because the way that Microsoft words the message a lot of people miss the real important parts. With the right information this will helps tech support help you address your problem quickly.
The first thing to look at is the error message. A lot of times you will get a message like the one below that states "PAGE_FAULT_IN_NONPAGED_AREA". In the case of this BSOD the error screen the error code is a generic one of 0x00000050 so we have to rely on message that tells us that the problem was with the memory or the page file.
The next thing to look at is the error code. Note you really do not need the info between the parentheses for standard trouble shooting.
So with both pieces info this will help tech support figure out where the issue is at and where to troubleshoot.
Note the file name that the BSOD list normally is not important in troubleshooting the in most cases it just point to the point where Windows had the problem.
on Apr 14, 2010 | Computers & Internet
My PC with 865PE Neo2-FIS2R doesn't boot on SATA HDD... It actually runs windows server 2000. but after an unexpected power shutdown... the pc always boot on Managed PC Boot... upon checking on the Boot...
Hi Good day!! well i think your board didn't detect your HDD for some reason:
1. unexpected shutdown
2. cable not properly connect in HDD to motherboard
3. HDD have been damage because of improper shutdown.
here are the step to detect your HDD
1.pull out your cable from the HDD and then re-insert it make sure it its inserted properly.
2.go to CMOS and then in the "MAIN menu" check the primary master, primary slave, etc. in the primary master your HDD should be detect there. if not enter your primary master for auto detecting.
if nothing happens and still not detected you must replace the cable of your HDD.
Pls. Reply to help you more
Regards
JR
Oct 07, 2010 | MSI 865PE Neo2-FIS2R (MS-6728-030)...
When i plug the hard drive my computer wont detect. only the bios can detect.and i cant reformat it it says.a problem has been detected. i boot it from cd and after the windows setup it displays" a...
This usually happens when u fit any hardware to the system....The information which u gave seems its "Blue Screen of Death" or "BSOD" ........ if u have seen this screen only after u plugged in yr HDD, try with other HDD. Perhaps there might be an error with the HDD which u have plugged in.
Jun 13, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
A problem has been detected. i boot it from cd and after the windows setup it displays" a problem has been detected and windows has been shutdown to prevent damage to your computer the problem seems to be...
If you're running Windows XP (Any version) or Vista open the link provided below for instructions on how to repair you're master boot sector other wise known as fixmbr; http://helpdeskgeek.com/how-to/fix-mbr-xp-vista/
Read everything.
Mike
Jun 03, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
Windows has been shutdown to prevent damage to computer
try restore ur system to factory default state when u purchased it as new u can do that as follows
from ur backup OS cd
or try this
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
if the problem persists after this then i am 100% sure about hardware malfunction that is RAM problem kindly replace and check if it works or if u have two RAM chips installed try each one at a time to find the faulty one
Mar 01, 2009 | Toshiba Satellite A135-S2276 Notebook
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
Computer
windows are corupted somebody has forced ur computer to shutdown manually u need to repair ur windows first by the windows cd or needs to perform clean installation
May 20, 2008 | Gateway GT5220 PC Desktop
Boot problem
Was the operating system installed on another computer? Or a computer with different hardware? If so the drivers for the hardware are not configured properly on the HD or in the BIOS. If this is the case you should format the HD and re-install the OS.
Aug 15, 2006 | Jetway N2VIEW Motherboard
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
