Question about JVC AV-27D201 27" TV
Jvc av27d201 tv screen problem
Hello i have a tv screen issue with my jvc tv. the issue is that the screen distortes and i get multiple lines throughout the screen and periodically will go to a bright vertical flatline in the middle of the screen. often all i need to do is tap around the screen on the outside of the tv and the picture comes back. over time im having to smack the tv more often and sometimes harder to get screen to come back. most of the time when i get the screen back it will give me a perfect screen until i turn it off. althouth this problem is getting worse. is this a possible part replacement issue and if so what part. it seems the tube is fine because i can still get a perfect picture at times. is my tv a throw away or do you think it can be fixed?? thanks shawn
  • shipwrecksim Jul 17, 2008
    thank you for the reply.............question: is v/o ic pin on the board? and does the board need to come out of the chassis for resoldering.
    also what does the v/o ic pin look like? how do i identify it?
    thank you for your time and knowledge.
  • 71 Answers
You need to have the vertical output IC pins resoldered
Posted on Jul 17, 2008
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Jvc lt-40fh97 40" LCD Hdtv
You need a repair guy for this one.
Feb 28, 2008 | Televison & Video
JVC AV-48WP30 problem starting up
The old video card has seen better days, methinks. All those symptoms lead one to conclude it needs a 'substitute' to enter the field, or call a long TV time out(too much pro and super bowl isms, eh?)..
Are you planning on doing this yourself?
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
I have a samsung model: LN-T4061FX. when turning on the tv, it has a distorted picture, the sound is good. if i smack that **** out of the top of the tv after multiple tries the screen will eventually
flext tab bond is the most likliest cause. They tend to lose their bonds and then usually hitting the top edge of the screen will lock it in. Flex tab issues will make part of the screen take on distortions and slow response of the pictures movements in the screen
Aug 05, 2012 | Samsung Televison & Video
Top of picture has distorted curve
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Distorted image and color separation and overlap
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Pioneer SD-532HD5 53" Rear Projection...
JVC Model no: AV-48WP34 Projection Problems
OK, problem seems in convergence section of TV and can be confirmed by testing voltage supply as mentioned in schematics.
You can download service manual copy from Manual Zone for small fee and it has schematics, exploded views. board location, part numbers info.
Let me know if you need further help.
Thanks.
May 07, 2009 | JVC Televison & Video
My 56'' jvc av56wp30 tv screen is doubled only twords top o screen
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 19, 2008 | JVC AV-56WP30 56" Rear Projection...
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
JVC AV-27D201 27" TV Logo
185 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
