Question about Akai LCT3201AD 32 in. LCD Television
Cannt get tv to change chanel
Comes on but wont change chanel . it only shows no signal on screen which is a blue screen and with trying to change it only goes to video screen wth contrast on top of screen and advance picture adjust at bottom if leave idle it goes into like a sleep mode after about 5 mins need to know how to get control back
  • 3 Answers
Check the mode the tv is on (Use "Source" button on remote to change modes). There are several modes to choose from.
Posted on Jul 18, 2008
Blue Screen
Hello, If you are using this combo with cable and the channels just coming through, you will need to replace the tuner(mounts vertically on the main board and it's located directly behind the cable/antenna connector). If you are trying to use this TV with a set of rabbit ears, the free signal channels turnes digital last year and that is why you get nothing. The tuner as an assembly is still available from a couple of sources: Partstore.com and Union Electronics(johnl@ued.net)
Apr 23, 2010 | RCA T19064 19 in. Combo
TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Apr 13, 2010 | Sanyo DS13204 TV
The tv works but i can not get it to receive any signal from any source.the menu comes up perfect.
When you change chanels, do the number just go up or down and the screen stays blue?
Let me know, I think that I can help if you can post back to this comment.
Thanks
asnowman
Dec 07, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Blue screen
the problem of ur tv is tuner,try to solder the tuner
Sep 28, 2008 | JVC AV-27120 27" TV
If you still see some signs of life on the screen, it means that there could be something else wrong in the main board not the power supply.
I would suggest to measure the voltages from the power supply, specially the 5VDC.
If there was a power surge is more likely that it damaged the main board because the power supply is not well regulated to control the output voltage to the main board and other circuitry.
Let me know if you need further assistance.
Jul 16, 2008 | Televison & Video
TV wont read any of my game consoles input signal
i had tht EXACT same tv in white and i used to play game systems on it. eventually i got bad joo joo and it stopped working :/
May 15, 2008 | Toshiba 36A50 36" TV
Tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Apr 01, 2008 | Televison & Video
Mono setting?
What channel is it and when they tune in that channel, is the picture nice and clear or is it grainy and snowy before the screen goes blue? On some sets, if the signal is weak, the picture will go blue. This is called Blue Screen and is there so you do not see very poor, grainy and snowy pictures. Some sets will have an option in the menu to turn the blue screen off.
Aug 27, 2007 | RCA 24F512T 24" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Akai LCT3201AD 32 in. LCD Television Logo
162 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
