Question about Kenmore 23822 Top Load Washer
Oil inside drum
I have question for a freind. How would oil residue be inside the tub. When she took out her clothes, there was an oily substance on them. Looking for a starting point. I can not think of any way this could be happening. Your help would be appreciated.
  • 254 Answers
Sometimes if your transmission is leaking oil it can creep inside the tub, tilt the machine back if you see oil underneath it then you"ll know if you have a leaking transmission.
Posted on Jul 16, 2008
Oil leaking fridge door
you will find that it is ( sealer mastic) residue they seal off door and cabinets with, when the cabinet or doors get warm ( from ambient temp or even excessive heat from mullion heaters the mastic liquifies sightly and hence an oily substance nothing to worry about , see it a hundred times
Mar 15, 2014 | Westinghouse Refrigerators
MY Estate TGDX640JQ Gas Dryer PROBLEM IS AS FOLLOWS ALL THE CLOTHING GOT BLACK SPOTS ALL OVER (DOESNT COME OUT ) SOMEONE SAID ITS FROM THE DRUM! ANY ADVICE?
It could be your washer leaking oil into the tub
Check paddles inside dryer drum for looseness if something oily got under
the paddles it will leak onto the clothes
Check felt strip at the back (and front) of the tub if it came off it could transmit junk into your dryer
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Estate TGDX640JQ Gas Dryer
Stains on clothes after washing. Appears to possibly be oil residue. Is there a rubber seal or part that may be leaking inside the drum?
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
Aug 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
GWL10 leaving dark streaks on my cold water whites.
Hi Barla 2,Just read your posting.Now are the dark streaks like an oily substance?Is you machine leaking or has become noisier on the spin cycle?The only place this machine will get oil into the water is from the main bearings.But this is only the case if your main seal is faulty.Please reply with the additional information and I can help you rectify this problem.
Jun 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Does my belt need replaced?
If it is greasy and not oily, the belt will need to be replaced, there is slight possibility that the bearing seal under drum is leaking oil,
Jul 09, 2009 | Washing Machines
Maytag Nepturn TL FAV6800 Grey spots/debris on clothing
Hello davidsonrepl,
I was waiting with someone with more experience to post back on your issue. I haven't experienced this issue it but I would not rule out a transmission seal failure causing your oily grey substance in the wash tub. If you want to investigate further you can get the Service Manual from here
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
take a look at page 38 and on and see if you feel OK with a tear down to the transmission.
Feb 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
Kenmore 23822 Top Load Washer Logo
174 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
