Question about HP Officejet J5780 All-In-One InkJet Printer
WHEN I HAVE AN INCOMING CALL MY FAX MACHINE COMES ON AFTER 2 RINGS HP J5780 HELPPPPPPPPPP
MY NEW HP J5780 IS INSTALLED BUT WHEN I HAVE AN INCOMING CALL MY FAX COMES ON AFTER TWO RINGS , HOW DO I SET IT TO GO LONGER.
    Novelist:
  • 106 Answers
the issue that you have has something to do with the "Rings to answer", for you to change it follow the steps..
1. press SETUP BUTTON on your printer
2. Scroll down and look for BASIC FAX SETUP, then press OKAY
3. Inside Basic fax setup, scroll down and look for RINGS TO ANSWER, then press okay.
4. It will give you choices there, just look for ANSWER ON RING 6, then press okay,
tadahhhh!! THAT SHOULD WORK.
thank you so much.
adonscott
Posted on Jul 17, 2008
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Can i receive faxes if so how my phone is hooked up to my fax and I can send them just fine
You need to push the "auto answer" button your fax machine so that it knows to answer the incoming call. The auto answer button is on your printers keyboard, usually in the upper left hand corner and has a little red light next to it. When you push this button, the fax will answer all incoming calls. You can set the number of rings to answer through the menu on the computers keyboard. Look for the menu key and use the up and down arrows to scroll through the options until you see fax set up.
Nov 11, 2010 | HP Officejet J5780 All-In-One InkJet...
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Fax sending but not receiving. If I hear the fax ringing I can press the (Start fax 'Colour') button and it will connect and come through but if I am not there to press the button it will just ring out.
Go in your settings on the fax machine and select the option to tell the thing to automatically pick up in 2,3,4, etc., when an incoming fax signal comes in.
Oct 26, 2009 | HP Officejet J5780 All-In-One InkJet...
My fax goes off periodicall when a call comes in.
It means that your fax machine is "answering" the incoming call before you pick up the handset. Usually, the factory setting on the fax machine picks up after two incoming rings. There are three ways you can address this issue: 1.) You can either change the number of rings to, say, five incoming rings to give you enough time to answer the phone before the fax machine picks up, or 2,) you can find out if your fax machine has a feature that allows for the voice hook "click over" that will allow you to override the fax when you pick up your handset, or 3.) turn your fax machine off until you need to send a fax.
If you want to investigate number 2.), then you'll need your operator's manual.
Good luck.
Aug 28, 2009 | Office Equipment & Supplies
I am having problems receiving a fax.
Check the number of rings your fax machine is set to. Chances are, the answering machine is set up for 4 rings and the fax machine is set up for 6. If this is the case, change the number of rings on your fax machine to 2 or 3 rings to ensure an incoming fax will go directily to the fax machine. If the fax doesn't recognize the call as a fax, it will go through to the answering machine.
Jul 17, 2009 | HP 1040 Plain Paper Inkjet Fax
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Got new hp elite m9402f computer but new hp fax doesnt answer
hi there,
initially you have to check and correct this few settings.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the main tray.
2. Remove any originals from the document feeder tray.
3. Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers. Or, turn off the Auto Answer setting so
that the device does not automatically answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press the left arrow or the right arrow to select Fax B&W or Color fax.
b. Press Start.
c. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Hope this initial info helps you.
micromaster-
Jan 19, 2009 | HP J4680 Office Jet All-In-One Printer
NUMBER OF RINGS TO ANSWER FAX
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the HP All-in-One, because you want the answering machine to
answer the phone before the HP All-in-One does. The number of rings to answer for
the HP All-in-One should be greater than the number of rings to answer for the
answering machine.
For example, set your answering machine to a low number of rings and the HP All-in-
One to answer in the maximum number of rings. (The maximum number of rings
varies by country/region.) In this setup, the answering machine will answer the call
and the HP All-in-One will monitor the line. If the HP All-in-One detects fax tones, the
HP All-in-One will receive the fax. If the call is a voice call, the answering machine will
record the incoming message.
To set the number of rings before answering from the control panel
1. Press Setup.
2. Press 4, and then press 2.
This selects Basic Fax Setup and then selects Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press or to
change the number of rings.
4. Press OK to accept the setting.
May 14, 2008 | HP Officejet 4315v All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
