Question about Toshiba Satellite M45-S2692 Notebook
Keyboard keys not working
Hi prb started early june... then 'P" key worked and shift key worked but "shift + P" would not work.... then it grew to the whole right side of letters
hjkl
yuiop
now the FN button works but i cant do Fn + f8 - f8 works on its own....
ive been told to airblow the keys or take the keyboard out and see if connector is loose... i took out the H or P key and put then backk.. they are not sticky nor does liquid damage seem to be an issue? what do you recommend i do first
thanks
    Genius:
  • 2,028 Answers
Take the keyboard off and check the connector to see if it has worked loose. Disconnect and clean both the keyboard and motherboard connections, then put it back together and try it. If it still doesn't work properly then you will need to replace it. The keyboard is one of the most used devices on the machine, and although they're built to last, they do wear out and/or malfunction.
Posted on Jul 16, 2008
Few keys not working on keyboard
Should replace key board. Moisture and keyboards do not mix.
Jun 14, 2017 | Microsoft Natural Ergonomic 4000
Left shift key not working
Hi Marcy,
Check that the key depresses all the way (same amount as other keys next to it). If so, then the most likely problem is that the keyboard has failed. You can have the keyboard replaced fairly easily.
Keyboard for the Dell Vostro 1520 costs $20 or less depending on where you buy. You can view YouTube videos on how to replace the keyboard or have someone professionally replace it for you.
Keyboard replacement on YouTube
Aug 06, 2012 | Dell Vostro 1520 Laptop
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Hi my sony vaio vgn-sr13gn, shift key does not work at all. not even in Command promt. Both shift keys don't work. What can I do?
A friend of mine has the same problem and i stumbled on your question today. This problem occurred with the Vaio VGN-FZ11E, after very very modest usage, no scratches or damage visible whatsoever.
There's one option out there:
"I found that if you hold down both left and right shift key at the same time (did this for several seconds), it somehow solved the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut..hopefully this will help you and other people that have had this problem."
Quoted from here
If that doesn't work, seems to me the remark of Benwabnick seems to be the solution, as posted below.
579a389.jpg benwabnick
Rank: Guru sony.gifSony Expert
Rating: 89%, 428 votes
the contact underneath the shift key itself is starting to go bad. Its a common issue with sony laptops, the keys can wear out pretty quickly. You'll have to get another keyboard.
BR
Jul 19, 2009 | Sony VAIO VGP-WKB1 Keyboard
Shift key problem
May 05, 2009 | Sony VAIO VGP-WKB1 Keyboard
Shift Keys not working properly on ACER notebook
The 8042 keyboard controller has been integrated into one chip with other I/O functions so I doubt you can replace it as a single IC and I'm afraid that is what has failed. It is an extremely rare failure but I guess it has to happen some time. The keyboard is kind of a polled matrix so it only takes the failure of a single line to bollix things up.
I think what you are talking about here is a motherboard exchange or repair.
Dec 13, 2008 | Acer NSK8458AN Keyboard
Nov 02, 2008 | Compaq Keyboard
Split keyboard & capslock shift function
I had a similar problem and noticed I hit the F Lock button. On mine it was a one way plunger stuck down. This caused the problems you mentioned on mine. Prying it up with a paper clip had my unit working immediately. Good luck!
Oct 30, 2007 | Logitech Cordless Desktop MX 3000...
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
165 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
