Question about Logitech MX 700 Mouse
Flahsing Red Light
My MX 700 mouse stopped working today. I pressed connect a couple times. The mouse is in the base and the red light just keeps flashing. I tried changing the batteries, although admittedly they were not rechargeable, so I put the rechargeables back in. I figure they can't be dead if the light keeps flashing. I unplugged everything, rebooted and plugged it back in, my computer recognized the new hardware but still the mouse won't work - it's too busy flashing that damn red light. Please help.
  • dlryan24 Jul 18, 2008
    Thanks for your response. As mentioned in my email, I pressed the "Connect". There does not appear to be a "reset" button. I pressed it first on the base and then on the mouse. Unfortunately, the mouse still continues to fast flash red. Any other suggestions?
    Cheers.
  • 38 Answers
Now what you have to do is look for a reset button on your mouse and your wireless mouse signal receiver.
When the receiver and mouse both are on press the reset button on both of them one by one.
This should solve the problem.
Posted on Jul 17, 2008
  • Gavendra Shah Jul 18, 2008
    Hey go on to this link.
    Hope it would be helpful.
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
Microsoft Wireless 4000 Mouse - No Red Light on Base
The red laser light stopped working on mine and it turned out to be the connetion between the battery tray and the circuit board. There is a metal tab on the circuit board and a matching one on the battery tray. When the battery tray slides in correctly the two tabs touch and viola (!), my red laser light came back on. Maybe one tab or the other got bent when I slammed the tray in crooked when replacing a battery- who knows.
Nov 01, 2009 | Microsoft Wireless Optical Notebook Mouse...
Red light doesn't come on ~ Microsoft optical notebook mouse 3000
Look for a small button that protrudes where the receiver is placed at the bottom of mouse. There are two possibilities for turning on the red light, one is that said button is stuck,if that is the case push it down a couple of times and see if the red light goes on, the other is that the button is broken at it's base. Also check that battery contacts are clean and hold it firmly. Good luck!!! Chawah.
Mar 15, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
I recently purchased the cordless mx 3200 laser desktop (ie keyboard and mouse). I have been able to get the mouse working, but not the keyboard. I keep trying the connect buttons but there seems to be...
Push the connect button on the base - the light on the base should flash. Push the connect button on the keyboard. The light should stop flashing. (This is the generic Logitech way - individual models may vary slightly.)
Sep 10, 2008 | Computers & Internet
Stopped recharging
Two things: 1) This mouse and charger does not like rechargeables larger than 1800mAH. The light on the front will(sometimes) go red if you use a higher rated battery than the 1800mAH. You said you replaced the batteries, but might want to check their rating. 2) My mouse gets harder and harder to get a good connection when putting it in the cradle. Might be the contacts are getting dirty. When you put it in the charger, you should see the optical beam (red on the back) go out and the green light on the front turn on. If this doesn't happen, it isn't connected.
You do have the cradle plugged in and the batteries installed the right direction in the mouse? I know it's obvious, but the questions always have to be asked.
Aug 05, 2008 | Logitech MX 700 Mouse
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Jul 21, 2008 | Logitech MX 600 097855036162
Mouse optico doesnt work
dear,
The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
hope it will fix your problem
Jun 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Logitech MX 700 Mouse Logo
1,372 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
