Hello there>
Yes there is a fuse inside of the case but you have to remove the outer shell first by removing the screws around the outer back then the side screws then the case should slide back and lift off
Then look at the front on the right side and you will see what looks like a small electronic board the fuse will be on there it simply pulls out of the holder and then the new one goes in there looks like this one i have posted below Now if this dosent work you have a problem with the power inverter or the megatron
