Question about Tomtom GO 910 GPS Receiver
Unit not working on batt pwr - ok on wall pwr
Hi
i have not used my unit for 2 months - the unit does not load after a full night of charging while off... green light was on...
it works when connected to wall power ac/dc ... do i need to change my battery?
    Scholar:
  • 84 Answers
It sounds like the battery won't hold a charge. Unfortunately, this doesn't use normal batteries that can be changed easily.
Posted on Jul 19, 2008
HP Pavilion Dv6000z will not turn on
Florida Bob,
Battery is part of the power/charging circuit. As you have found it needs to be in place; kaput or not.
Believe your problem to be Power MOSFET's.
This will explain why,
http://www.fixya.com/support/t15330613-hp_pavilion_dv8_not_starting_up
(The Mayohardware article)
Now you may know what is wrong, and where to get replacement parts, and how to replace.
This is the HP Support link to the free Service Manual,
Main Support page for the HP Pavilion dv6000z Notebook PC,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3224052
Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3224052&
In the list you want the blue -
HP Pavilion dv6000 Notebook PC - Maintenance and Service Guide
USE an ESD wrist strap.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
http://www.ebay.com/itm/65W-CHARGER-AC-ADAPTER-FOR-HP-Pavilion-dv1000-dv2000-dv5000-dv6000-146594-001-/221082152535?pt=Laptop_Adapters_Chargers&hash=item337985ee57
18.5 Volts (DC)
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 09, 2012 | HP Pavilion dv6000z Notebook
This scooter has not been used for 18 months,it has 2 gel batteries and showed a full charge after o'night charge(greeen light) showing. How many kilometres should i get from it ?.it is a victory...
hi.
with good batteries, and under ideal conditions (flat smooth surface) this scooter should be good for up to 30 km.
this is highly dependant on the surface, slopes, rider weight, and battery condition, but with good batteries you should easily be able to do a round of golf.
the biggest problem you may have will be the batteries themselves.
after 18 months without use, the batteries may have suffered from a sulphur build up on the lead plates in the battery. this can mean that the batteries will show fully charged, but will not put out the full power. the best way to test this is to take the batteries down to your local car garage and ask them to do a "load test" sometimes called a "drop test" on the batteries. they will usually do this free of charge and it only takes a few minutes. a 100amp load test for 8 seconds should tell you the condition of the batteries.
if the batteries test ok, then you should not have any problems using the scooter for a round of golf.
hope this helps
Jun 21, 2011 | Pride Mobility Victory 3 Wheel Electric...
Low Battery notice kept coming on
TRY RESETTING THE UNIT - Also - charge the unit over night with a WALL CHARGER - this helped when mine pulled that same stunt. Eventually it went away after charging it over night in the wall. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES 5770b9e.jpg
May 03, 2010 | Garmin StreetPilot C330 GPS Receiver
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Turns on then off. I have bought a new battery. Still didn't work. Charged it for hours. Still nothing. Only 4 months old.
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair w.4 months and no cust damage it is covered under the warranty.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 13, 2009 | Kodak EasyShare M1073 IS Digital Camera
Battery doesn't charge to full
As batts get older they take longer to reach full charge.
There may be a problem with a cell or maybe or a bloc
Batts are made up of sets of cells which make up a bloc.
eg 6 cells = 12 V bloc
Most UPS units have more than 1 bloc inside.
Standard batts can last about 3- 5years, it all depends on use, temp, cost of ups, and type of batt.
Some ups units allow you to check the batts with sofware, 1 other thing you can do is... with the ups powered up and running,do a test by connecting a lamp to the ups and failing the supply, for a short time say 3mins this will test the batts can work on load.
Before you do this make sure your critical load is not powered up.
Hope this helps , let me know by voting, thanks for using FixYa.
Sep 14, 2009 | APC Smart-UPS 1000XLI (SUA1000XLI) UPS...
Power light blinks, lens door won't close
may be it got stuck try to move it by ur finger cuz mine one opens half some times so move it by finger ..... try it it might work for u ....
Aug 14, 2009 | Konica Minolta DiMAGE X1 Digital Camera
IPaq rx3115 working like PC not Pocket PC, need to plugin always
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
Hope this helps
Jun 01, 2009 | HP iPAQ RX3115 Pocket PC
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
Tomtom GO 910 GPS Receiver Logo
55 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
