Question about Hitachi 42HDT52 42 in. Plasma HDTV
Cannot turn on. Power light is not on. Have unplugged and replugged in. Tried a different plug. Have it plugged into a batter backup with other electronics - cable box and DVD player. Cable box and DVD player have power and are on. Not TV.
  • 2 more comments
  • jbeno Jul 16, 2008
    What do I do about a power supply failure?
    TV is only a couple years old. No sound or anything.
  • jbeno Jul 17, 2008
    I still have to get a repair person, but at least I'll have an idea as to what they should be fixing. Thank you.
  • Mark Kristiansen Nov 22, 2011
    I am just now experiencing this problem with my Hitachi 42HDT52A. What was the diagnosis for it and how much did it cost to repair? Thanks!
    Genius:
  • 2,035 Answers
If you would like to attempt a DIY, you will need a service manual to guide you. THis will help to trouble shoot the problem ...
Posted on Jul 17, 2008
  • Hitachi Master
  • 13,433 Answers
Check for a blown fuse in the power supply area. if you got warranty that should cover the repairs if not a simple blown fuse problem.
    Scholar:
  • 101 Answers
Some TVs require being grounded to turn on. Make sure the socket is grounded. If your UPS has a "building wiring fault" LED and it's lit, that could be the ticket. Also see if there is a separate power switch on the back of the TV, near the power plug.
Posted on Jul 16, 2008
  • Jerrod J
    Jerrod J Jul 17, 2008
    This is most likely a case of bad electrolytic capacitors in the power supply. If you are comfortable with disassembling and soldering in new capacitors, that is probably the fix. Otherwise you will have to take it to a TV repair shop, or send it back to the manufacturer.
    First check and see if it is under warranty still.
    product registration for warranty
    Otherwise...
    service locator
  • 2,322 Answers
How old is your TV?
Do you have any audio?
If you do not, more likely a power supply failure.
  • Jaime Hernandez Jul 16, 2008
    If it's a power supply failure, you should measure the voltages if you know how; from the power supply to the other circuit boards.
    Click here and ask them if they have a power supply for your plasma.
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
Acer 2310 travelmate, power button will not go on. There is no sound of a fan. It is in effect dead. Tried different outlet with no improvement. Unplugged everything and replugged it in.
ok, if there is no indecation that there is any power, I mean even no instant flash when you first try turning it on... sometime the power plug in the back gets loose inside. or the power adapter dies... I would try gently weglling the power plug while looking at the lights if anything happen then it is the plug. if nothing then I would try to test the adapter either by a multimeter or borrowing another adapter and seeing what happend... also try disconnecting the power and take the battery out, wait few seconds then put the battery back, then the adapter (all while looking at the lights) then try again.. still if nothing then it maybe the main board itself... best of luck
Jan 25, 2011 | Acer TravelMate 2300 Notebook
TV was working when the screen went blank and the red light on the front began to blink.. I have tried several options of plugging it into different locations. No luck.
Try tv unplug,replug it back about an hour later.Let the tv reset itself back to factory setting.The tv should work now.Not than,the power supply board is dead.The power supply board,that the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 06, 2010 | Akai Televison & Video
My Tv won't come out of standby mode. When I try to turn it on, it blinks a couple of times and cut right back off. I've tried unplugging it and replugging it in different sockets, but to no avail. This is...
Try the tv unplug,replug it back about an hour.See,if the tv reset itself.It should work,not than the power supply board have problems.That the board,that where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 27, 2010 | Emerson LC195EMX 19 in. TV
Blue light comes on and then clicks off after a
it sounds like a virus or error on the mainframe although it could be your battery try taking your battery out and then plugging it into the mains. then turn it on without the battery in but still plugged in to the mains there may be sumthing wrong with ur batter
Mar 03, 2010 | Packard Bell Easy One Silver 2120 Notebook
My belkins wireless light wont come on anymore?
* try connecting ur belkin router to different power socket * try with different power adapter * or else press the reset key for more than 1 min while holding the reset unplug the router power cable and plug it back again 3 times.--- while holding the reset u shouldnt release the reset while u unplug and replug. the interval between each unplug and replug should be 15 seconds. * then release the reset then unplug the power cable and plug it back * it has to work or else replace it with the belkin tech support
Nov 15, 2009 | Belkin (F5D72304F5D7000) Router
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Hitachi 42HDT52 42 in. Plasma HDTV Logo
327 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
