Question about Garmin iQue 3600 GPS Receiver
Garmin hotsync issue
I have a garmin ique 3600 palm and I can't get it to hotsynce with my computer. I am running windows xp. Is it not compatable? When I try to hotsync I get a message that says "the connection between your handheld computer and the desktop could not be established.
  • richmit Jul 17, 2008
    I upgraded to WinXP Service pack 3, and I get the same message:
    " The connection between your handheld computer and the desktop could not be established. Please check you setup and try again."
    I have the sync icon on tray. Right click and it is on local USB. I can't find any other solution.
    Thanks,
    Richard
  • sultkh Aug 01, 2008
    connection between handheld computer and the pc is not established.
I also have a Garmin iQue 3600i palm and I also can't get it to hotsynce with my computer. I am also running windows xp. When I try to hotsync I get a message that says "the connection between your handheld computer and the desktop could not be established".
How do I know if I have the correct hotsync software as I just downloaded it of the net, could that not be the problem that I’m having? I have read on one of the forums that I should right click on the icon in the tool bar and set it to USB but I’m not sure that I have the right software for the unit.
Posted on Dec 01, 2008
  • jayjaysmith Dec 04, 2008
    Thanks Guest!
    My problem has now been sorted out! thanks for your help
    Cheers Jay
Open up device manager while the unit is not in the cradle (windows button + Pause/Break button together then choose hardware tab -> device manager) or you can right click on My Computer and goto properties. Put the unit into the cradle and press the resync button and watch inside device manger. the unit will appear as an unknown device. right click on the unknown device and open its properties then choose to update driver and allow it to automatically install by checking the internet for drivers. It should work then.
Posted on Oct 28, 2008
I have the same problem as above it starts to install and then says you must turn garmin on - its only and contect to usb it is connected, did the property thing it shows local. checked garmin FAQ did what it said and got same answer HELP!!!!!!!!!!!!!!!!!!.
Posted on Aug 04, 2008
I am using Windows 7 and want to Hotsync my 1000s of Memo Notes from My Palm Treo 650, I got the latest Palm Desktop and Hotsync Manager but My Computer cannot Hotsync or even detet my Treo 650....Pls...
Palm Desktop compatibility with Windows 7 and 64-bit editions Palm Desktop 6.2 was designed for 32-bit editions of Windows XP and Windows Vista. You may be able to use this software with other versions of Windows.
Windows 7: Many users have successfully installed and used Palm Desktop 6.2 with Windows 7. Palm has not done thorough testing with a range of third-party equipment running Windows 7, therefore Palm cannot guarantee compatibility.
64-bit editions of Windows: USB HotSync is not supported. Instead, synchronize through a Bluetooth wireless connection: set up Bluetooth HotSync.
http://kb.palm.com/wps/portal/kb/common/article/49229_en.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 18, 2010 | Palm Treo 650 Handheld
Hey uninstall the program, download the newest one available and try again.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
IQ3600
Is it connected to the pc via usb? Try other usb port like the usb port on the back of your computer if your are using a desktop computer.
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
Is there a way to use ique 3600 with windows 7? ique does not syc.
I am using Windows 7 Ultimate 64 and the iQue did not work. There is no USB driver and as far as I know there isn't going to be one. However, I did get it working by installing Windows XP mode and the Windows Virtual Machine on my XP system. You need to check if your computer can run XP mode and there are Microsoft tools to do that. After you get XP mode installed and running, there will be a virtual XP window on your desktop. Plug the iQue in its cradle and plug it in to the USB port. Use your iQue setup CD to install the Palm desktop in XP as you normally would. At some point, you have to tell XP to attach your iQue to the USB port. Near the XP title bar, there is a USB pull-down menu. Use this to attach the device. It will ask for a driver. Just say to use the Garmin-supplied driver. Wait until this finishes successfully. Before trying a sync, open the Palm desktop and go to Hotsync/custom and change everything you can to "handheld overwrites desktop" and save this. Push the hotsync button on the cradle. If it doesn't connect, go to the USB pull-down and click attach. It should work!
Dec 08, 2009 | Garmin iQue 3600 GPS Receiver
It says i have no connection between my handheld and my computer when i try to hot sync
If you are trying to HotSync to a Macintosh, you need to install Lycestra's PDiQue software available at http://www.lycestra.com/ique.html before HotSyncing is enabled. PDiQue enables a USB conduit between your Mac and the Garmin iQue 3600.
Oct 23, 2009 | Garmin iQue 3600 GPS Receiver
No syncro
I updated to SP3 and installed 3600 hotsync after upgrade. No problems.
Suggest you de-instal and re-install Garmin setup CD for 3600.
My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
IQue 3600 sim card problem
from Garmin:
Question: Why wont the PC recognise my the SD card in my iQue 3600?
--> Answer: Go to My computer and look for the following directory:
  • C: > Program Files > Palm > (user name) > file called 'sync'
  • Double click on this file and delete the four bottom rows that will look something like this:
"SlotId=0
MediaType=1935960423
DisplayName=SecureDigital (SD) Card
InstallDirName=Slot-SD"
  • Then try a HotSync as normal, it should then 'see' your SD card.
  • If all fails delete a second user name as sometimes this interferes.
Mar 14, 2008 | Garmin iQue 3600 GPS Receiver
Why will my Garmin not sync into my computer?
First, right click the hotsync button in the task bar and make sure "USB" is selected (assuming you're using USB...).
If that doesn't work, let me know.
Oct 06, 2007 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
457 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
