Question about GE (GTS16BCS) Top Freezer Refrigerator
Fridge is warm, freezer works.
GE fridge freezer model: TBG14NACBRWW No.: TT844673
For two days now, the fridge compartment is not cooling, but the freezer is colling and the light is lit when door is open.
I have the temperature dial set to 7 and a switch that has a defrost image to 0 (off).
Any ideas?
  • lianegourd Nov 14, 2008
    the fridge section on my GE is getting warmer because there is ice forming in the two holes at the top of the fridge section. the freezer is fine. the defrost timer is also fine. the gas is fine. i'm not sure if it could be the element.
    thanks
  • Ken Bledsoe May 11, 2010
    Does the fan inside the freezer compartment work?
Smilar problem, but the model is GTH15BBMFLWW
Posted on Aug 20, 2009
Why are my fridge and freezer to warm?
Sounds to me like your freon is low. That is the gas fridges use to cool things down.
I may be wrong but I would get a repair man to check the freon pressure first.. Low freon is caused by a small leak in one of the lines or in the compressor its self. I had an old fridge and the freon went low just over time.and had to be topped up.
Jan 13, 2015 | GE Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer works great, fridge not cold. about 60 degrees in fridge. had repair man look at the fridge, said the mother board, was bad. panel inside freezer iced uped. fridge seem to get better for about 2...
And you are posting because,.......????? You are looking for a second opinion? Don't like the repair estimate?
1. Your freezer is not working great. If it is frosting up, frozen packages will soon beging to soften also.
2. All of the cooling takes place in the freezer compartment. A fan blows air over the coils in the freezer, and directs some of it into the fresh foods side to cool it. When the coils become blocked with frost, the air can no longer flow into the fresh foods compartment. Result is warming of FF area. You may also see freezing in the bottom FF bin, water dispenser not working, FRZ section warm, etc.
3. Manually defrosting the coils will temporarilly solve your problem, but it will reappear in a few days to a week or so. (depending on door openings, ambient temp, etc)
4. The motherboard controls the defrost interval and (although not the most common) certainly can be a cause of defrost failure. If a qualified servicer diagnosed it as such, it most likely is just that.
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
GE (GTS16BCS) Top Freezer Refrigerator Logo
327 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
