Question about Sewing Machines
Simplicity 4 thread EZLock 880 pressor foot settings
I need to kow what to set the pressor foot on for regular stitching. I have a red knob with 6.5-7.7 m and * settings along with 5.5 - 4.7. I have misplaced my book.
Any suggestions
  • Sewing Machines Master
  • 1,388 Answers
Easiest way to get the tensions right, use 4 different coloured threads
Make sure the tension disks are a length of fabric in a see saw fashion through each tension unit.
....set all the dials to 3 or 4 then sew test.......take a look at what needs attention, make a small adjustment and test/adjust until the needle threads are firm and the looper threads meet neatly at the edge of the fabric with just the absolutely tiniest hint of being loose.
Posted on Jul 18, 2008
How do I set machine to sew a gather stitch with a regular presser foot (like the old Singer)
You need to make a row or two of long stitches and then pull up the bobbin threads. For best results use the longest stitch you have (probably 6) then set the tension for half of that.
If you have a gathering foot then follow the instructions for that.
Oct 12, 2014 | Brother Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
How do i fix the tension? i've been playing with the knobs for hours, but the threads are still too loose on the fabric.
Try decreasing your stitch width and this should help. Put your tension dials on 4. Also make sure when you thread your machine your presser foot lever is up to allow you to get your threads through your tension discs properly. To test the tension (usually set at 4 on all 4 knobs) when you thread around the knobs pull the thread on both ends like you're using dental floss around the discs under the knobs so you can feel the pull (tension) on the thread. Let me know if this works for you.
Aug 22, 2010 | Juki MO-654DE Mechanical Sewing Machine
Changed thread on serge pro SW 432. Now no chain or stitch.
Sergers can be tricky to thread.
Remove the thread.
Raise the antenna to it's highest position.
Open the tensions - setting zero.
Lift the presser foot.
Open the door on the serger and turn the handwheel until the upper looper is at it's highest point.
There should be a threading guide on the front of the machine or on the inside of the door.
Follow the threading sequence as this greatly affects the stitching.
Mar 13, 2010 | Simplicity Serge Pro SW432 Mechanical...
Necchi do you adjust thread tension on top thread
Before the thread goes though the uptake lever, it goes though the tension (a round "knob" with numbers).
When threading the machine, lift the presser foot. This opens the tension control so the thread can enter and then when the foot is down and you begin to sew, the tension setting will determine how much thread should feed to the needle.
The setting is usually around 4. However, if this is an older machine that has been used a lot and serviced a little, the tension may not work as it should.
Try different settings and if you cannot get a proper stitch, you will need to determine if the machine should be serviced or if you should purchase a new one - service and parts can be 1/2 the price of a decent, new machine.
Feb 28, 2010 | Necchi Sewing Machines
Need manual to know how to set tension. Singer Sewing machine Mod.#5932 Serial#N319411147
Singer Machines are probably the easiest to set..
first thing you need to do is remove the thread..
Set you tension knob/wheel to the middle number.
When you rethread the machine, stop when you get to needle. Put the presser foot down and pull the thread. If it pulls hard then so far so good. If it pulls easily, the thread is not thru the tension wheel right. Thread the needle and stitch about 10 inches on a medium wt fabric.
The stitching should feel even on both sides. If the top still is tight, loosen it up just 1/2 number.
So, if your middle number is 4.5, turn it to 4. If it seems loose, turn it to 5.
Apr 30, 2009 | Singer Sewing Machines
Necchi automatic BU supernova sewing machine
Hello! Hello!
Your machine is probably not 50 years old. I have one just like it that we purchased about 5 years ago. Necchi makes a very sturdy reliable machine. There are a couple of tricks, though. First, your bobbin thread has to turn clockwise. If it doesn't, it will either not sew, the stitch will look horrible or the thread will break. Second, threading it is pretty easy; however, I can't explain some of the parts. I would be happy to scan the diagram and e-mail it to you. E-mail: The tension should be set at 3 unless you are doing a ruffle or close zigzagging (machine applique). For applique, I find that I have to move it to 2. For ruffles or gathering, set it at 0 and your stitch width to 4. Another trick is to hold the top thread for the first 2 stitches. This alleviates a bobbin catch at the beginning. Other things you will want to know are in regard to the two knobs. One is pretty simple. It has a line that gradually increases in a zigzag. This knob basically adjusts the width of the zig zag. Obviously, for straight stitching, you would make sure the straight line is towards the top. The other knob determines the type of stitch you want to do. The red stitch options on top of the machine can be done with #1, 2, 3, 4 or 5 at the top; however, I usually use #1. The blue stitches are really fun! Simply decide which stich you want and make sure the corresponding number on the dial is turned towards the top. Also, it is very important that you adjust the other knob to the largest zigzag possible AND change the stitch length to 4. Don't pull on the fabric from behind the machine as you are sewing, because the machine will go forward and backwards while making many of these stitches. The green A, B, C on the dial are used for the automatic buttonhole feature. In order to use this, make sure you have the button hole foot. It looks like a long rectangular piece of plastic with measurements on it and hollow in the center. Not sure if that description makes sense. Anyway, the first step is "C." Make sure you begin with the button hole pressure foot measuring "0". Also, change your zigzag width to the desired width AND change the stitch length to less than 1. (You will notice that this area has a green line on it.) Begin stitching. You should be moving forward. When you have reached the desired length, make sure the needle is up, then turn the knob to "B" (sometimes I make my zigzag wider for this part), begin sewing. You should not go forward or backward. This step makes the bottom of the button hole. I only make 3 or 4 "B" stitches. When done, make sure the needle is up, adjust your zigzag back again if you changed it for B, and set it on "A". This will take you backwards. If you started your button hole with the foot on 0, it will automatically stop moving backwards when you reach 0 again. At this point make sure your needle is up again, then set the knob on "B" once more. If you adjusted B before, do it again. There you are! You can use twin needles on this machine. It also works well with a walking foot for quilting. Oh! To wind your bobbin (starting from the thread spool) you need to slide the thread under the little metal knob sticking out on top of the metal "?" right above the tension and then insert it into the hole in the bobbin spool. Push the bobbin to the right. This locks it into place. Next, hold the outer part of the flywheel (round wheel on right side of machine) while turning the inner wheel towards you. This will disengage the needle and allow the bobbin to wind. Now you can press on the "gas" and wa-laah. It will slow down and almost stop when it is completed. Cut your thread, slide the bobbin to the left to unlock, tighten the wheel and you're done. If you have any more questions, let me know. Hope this helps!
Jul 27, 2008 | Necchi 3537 Mechanical Sewing Machine
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
