Question about HP Serial adapter (17302A)
Driver for hp 1730 flat screen monitor
I can not find this driver
please help
  • Anonymous Feb 21, 2009
    Need to get new driver for HP1730 monitor but the link to this on HP.com is broken
Mouad tahiri
Posted on Aug 25, 2009
HP 1730 driver windows 7
what i know is that monitors don't need drivers. if your monitor is new then i believe it is already windows 7 ready.
what you need to do is check the VGA cable if it is damaged. try replacing a new one. Hope this helps.
Jun 21, 2012 | HP 1730 LCD Monitor
Please help me, i got a hp 1730 lcd monitor. the problem is that the screen is turned white and no image is present like there si not sinc on the screen the menu is lose only a shadow on the screen and...
How many months or years of your monitor that you are using? Do you check the outlet, cables? It's seems that your monitor has a problem because i read your observation that your monitor seems to be replace a new one. That's the monitor's problem.
Sep 16, 2011 | HP L1730 (Carbonite, Silver) 17" LCD...
Hello, I can not split the base for the monitor hp 1730, can assist me please, stuck in the laptop position
You have to remove four screws in order to separate the monitor base from the monitor.
Check the manual (section "Setting Up The Monitor", subsection "Removing The Monitor Base") for images of the location of the screws.
You can download the manual using this link: http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01129544/c01129544.pdf
Jun 13, 2011 | HP 1730 LCD Monitor
Pls how can i play my DVD player with my hp 1730 lcd monitor i'v tried connecting through VGA but its saying ''out of range'' what do i do? Help!
The resolution (most likely the 1080p HD) is too high for your monitor
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00477225&lang=en&cc=us&taskId=&prodSeriesId=346693&prodTypeId=382087
. You will need to access the dvd player's menu somehow and reduce the resolution to one that is supported: ideally it should be the 480p SD one that your player surely supports. The exact procedure is in the manual.
Apr 13, 2011 | HP 1730 LCD Monitor
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 24, 2010 | HP 1730 LCD Monitor
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Computer will power up, but FPD 1730 screen stays dark, says "power saving mode" How to cure??
Its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Nov 16, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
My hp 1730 lcd screen is making a humming sound which seems to get lower when i turn down its brightness but doesnt go away any suggestions?
That sounds like the inverter that powers the back-light. Unless it's really annoying I would just live with it. It's probably more expensive to repair than to buy a new similar sized screen.
Oct 08, 2009 | HP 1730 LCD Monitor
Gateway flat screen monitor goes black when turned on
open monitor and look at the PC Board to locate some kind of DRY SOLDER or burn point , specially where a transformer is located , check re solder any solder point that looks suspicious , and try again , hope this helps
May 03, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor problem.
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Oct 25, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
HP Serial adapter (17302A) Logo
6,195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
