Servers
Problem for Servers
Generic problem for all Servers
Reply
By Vladez71 on Jul 16, 2008
its a canon Power shot brand new with SD /mini MMC/RS memory card
It uploads when i use tjhe usb cord from camera to computer but when i directly put memory card in front of computer nothing happens now
Solution #1
posted on Jul 17, 2008
Not Rated)
Misterdj
Rank: Wiz
Rating: 85%, 153 votes
Hi there again,
I am assuming you are using XP OS.....
I have a couple of questions for you.
Try this.............
With computer on and camera NOT connected,
Please look at my computer,
1.What happens when you connect camera to usb lead then connect the lead to the computers usb port?
2,Would it upset you if we use another way of moving your photo and video files from camera to computer?
3.Does Memory card work in another device or computer?
Solution 1 =================================
If usb did not recongise the camera on the usb port then it will be a software and hardware reinstall ,
Remove usb lead from computer
Go to Add/Remove from you control panel.
Remove the cameras software.reboot.
restart install software first and reboot,
do not connect camera yet,WAIT.
once restarted add camera via usb
should be good to go.....
If it does continue to give you issues then consult the manufactuerer.
Solution 2 =================================
if the usb is connected to the camera via usb lead to usb port on the computer and you can see the cameras' drive info then its more than likely you will be able to open and use this file ,if so you should be able the move these files to your computer too.
Solution 3 =====================================
Explains itself really-Replace it if you need to.
Hope this sorts out your problem.
I beleive your card reader may be poked,
Uninstall and reinstall try again, replace if presists.
these solutions I have put forward have been proven to work in many situations so good luck and let us know the results thanks
Was this helpful?
Yes
No
Popular Solutions for Servers
Questions and Unsolved Problems for Servers
Answer
Which San Vritual Appliance is the best for ISCSI SAN to support VMware and compare price as well
Answer
Can i change this server into a home pc and what do i need to do first
Answer
dear expert, please tell me about the E-1 Server how it works ?. and how many lines can it processed... (More)
Answer
nexian mobilephone
Answer
trying to log on to myspace page and/or my web site
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Servers:
Top Server Experts
Rank: Guru Guru
Solutions: 3607
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Server Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
