Question about SanDisk Sansa E280 MP3 Player
The screen wont come on
On my sansa e280 when i turn it on the screen doesnt come on but the blue light on the wheel does and also when i plug it up to the computer it doesnt find it. Also when i want to turn it off i have to hold the power button much longer.
So if anyone could help me solve my problem i would be very grateful
  • marooned Jul 18, 2008
    I actually have the same problem, I'll try to drain the battery.
    I also had screen frozen many times, in this case I use to open the player, remove bettery and replace it, wich takes less time than wating to drain battery.
    Problem Solver:
  • 20 Answers
Try resetting the player by holding the power button. your player may be "bricked" in which case you may have to get a return from sandisk.
Posted on Aug 03, 2008
E280 wont turn on, wheel only glows
For the e200 series player you can first try to RESET the player as next (solution 1):
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button. ( now the player should be off )
3. Press the Power/Menu button again to turn on the player, to see if the device is working normally again.
If the player still freezes after that, you can reload and update the lastest firmware (solution 2).
See next overview link:
http://kb.sandisk.com/app/answers/detail/a_id/4/kw/blue/r_id/101834
When needing more help, just add a comment in this same help request.
Jun 08, 2010 | SanDisk Sansa E280 MP3 Player
The blue ring lights up when I power it on but the screen remains blank..What could be the problem
your screen might be shot... i had an old E280 and its screen and headphone jack went bad after like 7 months, so the screen might be the problem...
Nov 21, 2009 | SanDisk Sansa E280 MP3 Player
When my e280 was playing the screen went black
did you drop it in water...if so i would suggest putting it in rice...it works! =) if that dotn help contact Customer Support
Aug 27, 2009 | SanDisk Sansa E280 MP3 Player
Screen went blank
Hi, I experienced the same problem this morning, my sansa player (e280, 8Gb) froze in the middle of a song, the screen went blank but the wheel still had its blue light on and i didn't know how to fix it bur then i figured how. If that's the case with your player too, then the solution will be to press and hold the power button till the blue light goes off (abt 8-10sec) and then just restart the player. It should work.
May 08, 2009 | SanDisk Sansa Fuze MP3 Player
Well my Sansa e280 wont come on. But when i plug it up to the....
Change the USB mode from MTP to MSC and see if that helps.
Also, make sure the hold/lock is not engaged.
Jan 06, 2009 | SanDisk Sansa E280 MP3 Player
Sansa e280 fatal failure - black screen, unrecognized by comp, won't restart..
1. turn sansa clip on
2. slide to "hold"
3. press and hold center button do NOT let go...
4. plug in the connector cable
5. wait until computer recognises Sansa device
6. let go of center button
7. drag n drop files and you are all set
if that doesnt work you will need to go to the sandisk website to update the firmware on your device..
let me know if you anymore questions..
Please rate accordingly
Thank you
Computerrep
Oct 31, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 wont turn on
What i do is drop it not hard but a light drop and it should turn on than
Aug 25, 2008 | SanDisk Sansa E280 MP3 Player
Sansa wont work
Download the Sansa firmware upgrader and install it first. Then, hold in the volume + button on your Sansa player and connect the Sansa to your computer (while it is in the OFF position). The computer will recognize the player after you continue holding the volume + button for 5-50 seconds. Restart your computer. You will lose all files stored on the Sansa, but it will work again.
Mar 29, 2008 | SanDisk Sansa E280 MP3 Player
My Sansa E280 turns blue but no Sandisk screen comes up.
I'm SOOOOOOO excited i got it to work again. I took off the back cover and removed the battery while the scroller was on and blue, then right above the battery there is a black rectangle thing that was not flush with the rest of it. I pressed that in turned it on, and bam it was good to go. I hope you all have as good of luck as I have had. Let me know if it worked for you!
Oct 26, 2007 | SanDisk Sansa E280 MP3 Player
Black screen blue ring
i just had the same problem try opening the mp3 player and removing the battery, then put battery back in and it should start working again
Mar 10, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
