Question about HP Office Equipment & Supplies
The printer keeps printing alignment sheet before regular printing begins.
    Genius:
  • 1,447 Answers
Hi-
Try uninstalling and reinstalling driver, that should take care of the problem. Thanks and keep us posted for any progress..
Posted on Jul 16, 2008
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
When duplex printing I regularly get creased
Check the rollers for any mis-alignment. Try loosening them and re-aligning them again. It should'nt be too hard.
Dec 28, 2009 | Dell 5100cn Laser Printer
How to configure printhead alignment
Hi there, Aligning the Print Head
If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
Steps for Aligning the Print Head.
1) Press [Menu] repeatedly until [Maintenance] appears.
2) Press [Maintenance] repeatedly until <P> appears.
3) Press [Black] or [Color].
The machine print the head alignment sheet.
4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
5) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
6) Press [Maintenance] repeatedly until <U> appears,
7) Press [Black] or [Color].
The machine scans the pattern and aligns the Print Head automatically.
Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
Hope this help.
Have a good day.
Dec 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer won't respond to scan command (pixma mp450) and keeps telling me the cover is open when it is clearly not!
Press the OK button to
exit the error, and do
the print head
alignment again (from
printing of the print
head alignment sheet),
while confirming the
following:
- Set A4 or LTR size
plain paper.
- Confirm that the print
is printed properly
(no smear or nonejection
of ink).
- Fill in all the
applicable boxes in
the printed sheet.
- Place the sheet on the
platen glass in the
correct position and
orientation.
Oct 08, 2009 | Canon Office Equipment & Supplies
How can I stop my printer automatically printing out a test page when I switch it on?
every time u switch on the printer it will print the alignment sheet until you scan it.once the alignment sheet is printed ,keep it in the scanner glass and press the scan button.this will scan the alignment sheet.
Sep 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
How do i align my printer, it's printing blurry
Setting the Alignment:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
Apr 01, 2009 | Brother DCP-120C All-In-One InkJet Printer
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
Laser Jet 4 Plus
Make sure your sheets are aligned and tucked in with the paper feed rails, otherwise, it will slightly veer off one of the sides.
Also, if you haven't replaced the paper feeder rollers, do so, one must be worn out more than the other, and this also prevents the sheets from going through straight.
Hope That Helps!
Feb 01, 2008 | HP LaserJet 4 plus Printer
100 people viewed this question
Seeker5211
Seeker5211
