Question about GE 25881EE3 Phone
GE model 25881 5.8 GHz dual handset phone
I just got this phone and every few minutes it say press and hold memo key to get setup instructions. How can I make it stop doing that?
  • 3 Answers
DON'T hold the memo key. Use the book for set up instructions. Took me about 6 times to figure this out!
Posted on Sep 07, 2008
Handset display says "Connecting" I can't deregister. How can I get the handset to display "not registered"?
The procedures to deregister are, of course, specific
to each make and model number of cordless phone.
All of them are a LOT more involved than simply
removing the battery.
For some AT&T, VTech, Uniden, & GE model numbers
you might try the following:
For many AT&T models it is simple:
1. When the handset says "Connecting..."
enter *331734 [menu]
it will soon (chirp) and display "Not registered"
For many VTech models it is a bit more involved:
1. Start by taking off the battery compartment cover.
2. press [menu]
3. scroll up/down to "Settings"
4. enter * 7 8 9 0 #
5. if display reads "Test Base",
scroll to "Test Handset", press [select]
scroll to "next page", press [select]
6. scroll to "Register Clear?", press [select]
7. display asks "Confirm?" or "Register Clear??",
press [select]
8. display reads "Ok" (chirps), press [ off ]
(this is why the cover is off)
10. Wait ~30 seconds, re-connect the battery &
replace the cover
11. display reads "Not Registered"
For many Uniden models:
1. Press and hold the [END] and [ # ] keys at the
same time, after a few seconds the display reads
2. "System Reset, Deregister Handset"
3. scroll to "... Base Unavailable"
press [SELECT]
4. Handset (chirps)
press [END]
5. display reads "Not Registered, Place in base..." =====================================
For some GE models:
1. press "program[mute]"
2. scroll to "Handset Setup" press "program[mute]"
3. scroll to "Deregistration" press "program[mute]"
4. scroll to "Yes" press "program[mute]"
5. display reads "Not Registered"
Once you have the handset displaying "Not Registered"
you can follow the User's Manual instructions to register
the handset.
The model number for your cordless phone is shown on
a small sticker underneath the battery in the handset --
enter this number at to get a free
copy of the User's Manual if you need it.
Mar 14, 2016 | Lands Phones
I am trying to register my panasonic kx tga641es to the base. I have no instructions/user manual...can anyone help please???
I have similar model and setup should be the same..
1, Handset: press Menu
2, Handset: scroll using up/down arrow keys to "Initial setting" then press soft key Select
3, Handset: scroll to "Registration" press soft key Select
4, Handset: sroll to " HS Registration" press soft key Select
5, Base Unit: Press and hold (LOCATOR/INTERCOM/TRANSFER) for 3 seconds. The Charge indicator flashes. After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
6, Handset: 1: press soft key OK
2: wait untill a long beep sounds and the display shows the new extention number
**Registration should be complete**
Aug 25, 2011 | Panasonic KX TGA641ES 1Line Cordless...
For ge 25942ee4 5.8 ghz - i can't locate instructions. need to know how to correct the day and time on main base phone.
1. Make sure the answering system is ON.
2. Press fash/answerer/call waiting button on the handset to enter answerer remote
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confrm the setting.
Sep 30, 2009 | GE 25952EE1 Cordless Phone
No instruction manual
On the handset that is on the base is the one you need to use to set the time and date. It will also clear out the CL on answering machine.
On the handset without pushing talk hit the flash key. A message will appear on your phone and it says Answering machine. You can listen to all the options but to set time and date ---push the 8 button.
Set your time by using the phone keys such as it's 09:53 then look up in the right corner and use the + arrow key to set AM or PM. Then hit the # key. Then in the upper right corner it will say Mon---use the + arrow key to set the day. Then hit the # key. The message on your phone will say the day is and then the time is. Then hit flash. Then you can check your answering machine and see if that worked. This took me some time. I would not buy another phone like this again.
Mar 06, 2009 | GE 25952EE1 Cordless Phone
GE 5.8 ghz cordless phone
the menu will take you to registering the hand sets to the base unit
by deleting incoming calls you have disconnected from the line
follow the instructions in the user manual to get reconnected
if you do not have the user manual , go google and type in --user manual for ge ( model ) cordless phone --and down load the pdf version
May 25, 2017 | GE 27957GE1 Phone
Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Oct 18, 2007 | GE 25881EE3 Phone
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
GE Phone Model 25881
Per the instruction manual, there is supposed to be a switch on the base (look on the back or bottom) for TONE/PULSE mode. Here is a link to the manual: In the "troubleshooting" section, there is this entry: Dial tone is OK, but can?t dial out: Make sure the TONE/PULSE setting on the base is set to the type of phone service you are subscribed to.
Dec 31, 2006 | GE 25881EE3 Phone
Phone asks to press memo for setup instructions
We have that same phone and have experienced the same exact problem. I called the 800 GE support number but they couldn't do much except to suggest the norm - unplug, remove batteries, wait and plug back in. They also suggested that we call our phone provider and give them the REN number from the back of the phone. This has something to do with how many phones you can have connected at the same time. We called and they verified that there was no problem. Finally we switched out the 9 V transformer that came with the phone with a 12 V and things seem to be working fine. It's only been a couple of days but we were getting that annoying 'Press and hold menu button' at least once every 1/2 hour so things are looking up!!! ;)
Aug 29, 2006 | GE 25881EE3 Phone
GE 25881EE3 Phone Logo
267 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
