Question about Radio Shack Pro-94 Scanner
Scanner when i program scanner it say error
    President:
  • 2,761 Answers
A programming ERROR message frequently means that either you have neglected to enter a decimal point in the frequency OR that you have attempted to enter a frequency that is out of range for the scanner. It could, of course, mean several other things, especially with a trunking scanner. Here is a link to the owners manual for this scanner:
http://support.radioshack.com/support_electronics/doc61/61172.pdf
Bill B.
San Antonio
Posted on May 07, 2009
Problem after instalation. the SN does not function between the scanner and the instalation program?
click start, control panel ,add or remove programs, remove scanner program. reinstall with cd . after installing search for any up dates and drivers and install , follow instructions in the install manual as to when the scanner is switched on.
Jul 09, 2015 | CreoScitex EverSmart Jazz+ Flatbed Scanner
I saw the error "an error occurred during preview. if the scanner is being used. please wait for it to complete the task.and then click preview" when iam attempting to preview the scanned pictur how c
If you continue to get this kind of error after restarting the computer, you may need to update the scanner's device drivers or reinstall the included software. You should also make sure only one program or application is attempting to use the scanner by closing all but the one program you are trying use with the scanner. One last note - always either let the program you are scanning to operate the scanner or let the scanner invoke its default application by pressing the scan, fax or copy buttons on the scanner. Do not for instance try and scan an image into a running program that initiates the scanning process itself while also invoking a scan from the scanner's control panel. The two operations will conflict.
Nov 19, 2014 | Office Equipment & Supplies
How do I program the scanner. It keeps telling me there is an error when I enter anything. Any help would be greatly appreciated.
I have one of these scanners they are kinda hard to program uniden could of made it simple.....Ok you have to hit your function button first...Then hit your e button enter button the enter button and it will go to program...The enter button and the program button is the same just go to your enter button. e button this will put your scanner into program mode...then you can start entering your frequencies...if you don't have it in program mode it will show error...If you have any more problems you can e mail me randymarr570@msn.com
Jul 16, 2011 | Uniden BC72XLT Handheld Scanner
Error meassage keeps comming on when trying to program frequencys
that is because you are trying to program frequencies into the scanner with hitting your program button...hit your program button.. its your prg..button when you hit your program button then try putting your freq in...
Jun 18, 2011 | Radio Shack Pro-2018 Scanner
I have a Uniden Bearcat 30 Channel 10 Band Radio Scanner how do I program it when I put in the number it shows error
The ERROR message usually indicates that you've tried to program a frequency outside the scanner's tuning range. The BC60XLT top tuning range is the 512 MHz band, so you cannot tune any 800 MHz frequencies. For further information you can download and print the factory manual, at no cost, here:
http://www.uniden.com/pdf/BC60XLTom.pdf
Bill B.
Listening in since the 60's
Apr 01, 2011 | Uniden BC60XLT Handheld Scanner
I can not program the codes in to the scanner keeps comming out error
Unless this scanner was aquired second hand, the frequncy programming instructions should be included.
If not, please visit this site and follow the links for more info..
http://www.scannermaster.com/Articles.asp?ID=167
Sep 27, 2010 | Uniden BC370CRS Base Scanner
I have a uniden bearcat scanner model#bc148xlt and it seems to not want to take the local frequencys and it comes up error when you hit the enter or e button
You didn't mention what frequencies you're trying to program. BC148XLT coverage ends at 512 MHz, so you will get the error message if you try to program anything above that. Also, you must be sure to include the decimal point when programming a frequency into the scanner. I hope this helps.
Need the manual for your scanner? You can download/print it here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC148XLT%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
May 20, 2010 | Radio Communications
What steps do i take too program frequences. what are the frequences for charlotte north carolina?
with the scanner on, push the "man" (manual) button. If the scanner was scanning it should stop on one channel . Push the up or down arrow key until you get to the channel you want to program. You can also use the keyboard for direct access to a particular channel i.e. push "1" "4" "9" and "man" to jump to channel 149.
Once on the channel you want to program, push "prog" (program) then the frequency you want in that channel, including the decimal point. Push "ent"(enter). Your desired frequency should be displayed. Don't forget the "." (decimal point) or the scanner will tell you "error". Move to your next hannel to be programmed and repeat. If you put in a frequency outside of the radio's capability, you wil get an error message.
To find frequencies, look on the internet. The best site I have found is
http://www.radioreference.com/ .
Oct 27, 2009 | Radio Shack Pro-2054 Base Scanner
Error synchronising clock
I think after the installation of the scanner driver and the program you should check for the properties and then again restart the computer. if not re install the whole driver and program for the same. your problem would be solved
Oct 01, 2008 | Opticon OPN 2001 Mobile Data Collector...
Radio Shack Pro-94 Scanner Logo
144 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
