Whirlpool AWM5145/2 Front Load Washer Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. iv got a whirlpool awm 5145/3 washing mashine. it stopped working yesterday. it is getting power to it but when u select ur program it doesnt do any thing. it doesnt start. the only program that works is the drain function! any ideas?
Anonymous
Level 2:
New Friend:
  • Expert 35 Answers
  • Posted on Jan 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
35
Questions
0
Helped
8034
Points
108
Depending on the age of the appliance you may well need to replace the carbon brushes on the motor
2answers
W/machine not filling with water
Also ...The selector switch allows you to choose the wash, rinse and spin settings. When you set the desired program, it sends a signal to the water inlet valve to open the hot and cold water inlets. If the selector switch is not powered or unable to transfer the signal, your washing machine won't fill with water.
1helpful
My awm 5145/4 has stopped working! There is still power going to it but when you select a programme it does nothing,but it will drain,someone has suggested the brushes,where are these located on this...
Could well be the Carbon Motor brushes that are worn they last round 5 years hen need replaced..I lie under the machine to do this but you may find it simpler to remove the motor they are located at the side and are secured by two screws, parts cost around £25 per set.....
How do i open the filter cover for my whirlpool awm 5145/3 washing machine?
Tip is back a hair and remove the screws and bottom panel then grab the cap045bec0.jpg7d5c207.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I have whirlpool awm 5145 the counter turnsbut nothing happens
Check the lid switch. There should be a small pin on the lid that will push the lid switch down when it is closed. There are two wires going to the lid switch, jump these two wires together and if it works then replace the switch.
Unplug the washer before doing any work.
2answers
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
1helpful
Whirlpool awm 5145/4
FILTER MAY BE BLOCKED IRE CLOSE BYE
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Awm 5145
Possible your hoses into the dispenser box hv a problem; plug off wall. Open the top of the machine to examine the hoses.....
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
