Question about Whirlpool Refrigerators
Flickering display panel on Whirlpool american style fridge/freezer
  • Anonymous Aug 21, 2008
    flickering display
  • kuga Aug 21, 2008
    flickering display on whirlpool american fridge freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Posted on Sep 08, 2008
Hi, i need to set temperature for my 6th sense american fridge/freezer.. panel shows -24 deg for freezer and 5 deg for fridge..can you help me pls ?
There are buttons for fridge temperature and freezer temperature on the control panel. Just press the relevant button repeatedly until the temperature you want is displayed. http://docs.whirlpool.eu/_doc/501931501055GB.pdf
Jul 15, 2014 | Refrigerators
Where can i find the model number on my whirlpool fridge freezer, American style?
open fridge door and pull out second from bottom draw - the sticker is on the righthand side
Jan 03, 2011 | Whirlpool Refrigerators
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
I have whirpool fridge freezer american style and the temp lights flashing on and off wont turn off what can i be
Check the coil at the back of the freezer for ice buildup. Should there be ice build up, have it defrosted and cleaned. If that does not solve it check out the thermistor, also located at the back at a panel. It may have gone bad.
Nov 12, 2009 | Whirlpool Freezers
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I am trying to turn the whirlpool space 4 american style fridge freezer on. the fridge seems to be fine, but the freezer side temp display is winking and the temp control is not responding and the warning...
You have a common fault with the electronics.
Check on a large auction site for a repair kit.
Item number: 330363841350
It will only cost £30, better then a few hundred.
Hope this helps
Sep 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
May 21, 2009 | Whirlpool ES5FHAXS Side by Side...
Whirlpool fridge freezer (american style)
you have a bad control or bad sensor
May 11, 2008 | Freezers
Refrigerators Logo
1,050 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
