Question about Motorola Mobility RAZR V3
Record music I dont know where it tell you how to rec' music. Can someone help me with this .
    SHARCNET-USA May 11, 2010
    Who is your phone carrier? Verizon? Sprint? Each have different software versions. Typically you will use the voice recorder function.
    - Jim
    Brigadier General:
  • 7,752 Answers
Shar has told you correctly so you should contact your mobile provider
Posted on Aug 25, 2008
Ok so i just downloaded some music videos from youtube and i dont know what format i have to convert those music videos to for it to play on my nesa NSD-327/ NSD-327T. can someone tell me what format i...
Fisrt off have you actually read the instruction offense but I dont either! In the manual it will tell you what format the player can read. most popular is MP4 format. hit me up and tell me what device your recording your MP4/MP3's to.
Sep 13, 2011 | Car Audio & Video
I lost the owner manual so I don't know how to use it to record. Can you show me how to record it? or tell me the website where I can download the owner manual? My Lorex model is Sg7964
The manual is available here: . The direct link is: .
If the timer is not currently active, then for a basic recording, put in a tape that has the erasure prevention tab in place. Then press Rec/PlaySpeed (up or down arrow) to set the recording speed. If you want to skip the setup steps, press Display. Then press Rec. Press Stop to stop recording.
I hope this helps.
Apr 29, 2011 | Lorex SG-7964 VHS VCR
Not gettin to rec.
Take out the memory card, there is a little switch on it. One position is protected which means you can't record or delete anything from it, the other position is normal where you can record to or delete from.
Sep 27, 2009 | Zoom H4 Handy Recorder
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
How do I record my own voice using the t10? I need to record some memos and don't know how to do it
From the main menu go to prime pack select voice record and press the center button. to listen to the recording go to music recorded files. The voice rec's are named VCE_001, VCE_002 Etc the FM rec's are named FM_001, FM_002 Etc .
Mar 23, 2009 | Samsung YP-T10 Digital Media Player
I have just gotten VIsta and find that I cannot rec. YAHOO e mail
Rec? does that mean record? if that means record than do this. Go to your contacts menu in messenger and go to message archive you should have all your stuff there. And from there you can choose how long to keep the recorded messages.
Other than that i dont know what REC means. If anything. uninstall messenger and download new one.
good luck
Feb 16, 2009 | Yahoo Messenger
Just bought a DP-02 w/40gb hard drive
You'll first need to find some aux audio out jacks on your karaoke machine. You might need an adapter, but the basic idea will be to connect the aux out from the karaoke machine to an input on your Tascam DP-02.
Then on the DP-02 you need to assign whatever input your plugged into to one of the 8 tracks. Let's say you're using the left input (input A) and want to put the karaoke music on track 1. You'll press the 'Assign A' button on the DP-02 and while holding it then press the 'Rec' button of track 1. The 'Rec' button will flash rapidly to show its been assigned. (for reference: assigning an input is better described on page 23 of the manual). Then you'll want to arm track 1 to record. Press the 'rec' button for track 1 and it will start to flash slowly to show it has been armed for recording. Now you are ready to start recording. On the DP-02 press the large round play and record buttons on the lower right together to start recording and start your karioke machine playing. When the song is done press stop on the DP-02.
Now to record your vocals you'll need your mic to be plugged in (lets' say it's in input B). You'll need to assign this input to a free track (track 2). Press the 'Assign B' button and while holding it press the 'Rec' button for track 2 (rec button will flash rapidly). Then you'll want to un-arm track 1 and arm track 2 for recording. To do this press the 'rec' button for track 1 so that the light goes off and then press the 'rec' button for track 2 so that it flashes slowly.
So now when you press play and record together to record, you'll hear track 1 playing (the karaoke track you recorded earlier) and you'll be recording vox on track 2. Of course you'll also be recording whatever you hear in the room onto track 2 along with your singing, so in order to get a clean recording there (prevent bleed) you'll want to plug some headphones into the DP-02 and listen to those as you record.
That's pretty much all there is to it. Some variations if you wish to record the karioke in stereo vs mono (I gave you the instructions for mono here), and you may need to turn on phantom power if you have a non-powered mic, but the idea is basically the same.
Hope this helps.
Good luck.
Oct 24, 2008 | Tascam DP01 All-In-One Recording Package...
Problem in viewing the folder MICIN.DIR in my player but the files are visible in PC
I have mp3 digital audio player emprex (128 mb). Now i have some problem. When i recorded music from computer into my mp3 and after i want to listen it , my mp3 player didin't play and it didin't show my recorded music.But when i connect to my computer, i can see my recorded files mp 3 music. What should i do now?
May 04, 2008 | Audio Players & Recorders
It dont rec anything
Please repost and type right
Oct 04, 2007 | RCA M5001 Digital Media Player
Recording Problems!
You may try a different style DVD disc. Are you using (+), (-), or (RW) the DVD makes a difference. Here is the manual for your product. Check pages 9 and 10. These pages tell you the type of DVD disc to use, and what speed they can be used. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
