Question about Toshiba 50H72 50" Rear Projection Television
Two issues I have two issues with my 50h72 I believe one of them is my convergence amps, it looks like this: http://www.fixya.com/support/t419411-re_thanks_much the second issue is intermittent and shows up after the TV has been off overnight and we first turn it on in the morning: I suppose I should start with changing my convergence amps, then address this issue, but since I will have my TV gutted, it seemed worth fixing two issues whilst I have it apart.
  • 4,234 Answers
The convergence problem is either bad solder connections on the pins of the convergence ICs or defective ICs. Intermittant problems often are just bad connections. Resolder any joints that appear grainy or have rings.
Keep us posted.
Dan
Posted on Jul 23, 2008
    Genius:
  • 1,665 Answers
1: Try a hard reset by unplugging the power cord for 4 hours. That may clear up the problem if it were caused by a corrupted software code internally.
2: Try resetting any of the OSD items that may have anything whatsoever to do with picture parameters.
3: If you dare, go into the service mode and see if you can find anything that touches on this problem.
4: Call the Toshiba representatives and inquiry if they have a simple solution.
5: Take the set in for warranty repair if the set is still under the warranty program. (Or rather, have them come to your home as this is not the kind of set that is easily lugged around!).
  • 2,336 Answers
I would suggest to replace the STK ICs first as suggested in your previous post and you might end up fixing both failures.
Let me know if you need further assistance.
I have a 50 inch theatre view tv I bought 7 years ago. The sound is going on it. It is very quient and muffles sounding. Can I fix this myself? Thanks for your help. Looking forward to your...
http://www.fixdevice.com/smanuals/file/31187.html
Above is your service manual, i believe your problem will most likely be the STK device Stereo audio output amplifier, developing a fault, either that or the power to the Amp is compromised, so as always start with the Power supply first and work out. Replacing the STK device is not too hard, you need a desoldering tool, and a good 40 watt soldering iron with a fine tip and some rosin cored solder.
Also have a look at this master google link, have a look regarding the stk replacement in particular.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=Toshiba+50H72+service+manual
BE CAREFUL
Nov 11, 2010 | Toshiba 50H72 50" Rear Projection...
There is a double image on the screen, and the color is off, with a red tint
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Toshiba 50H72 50" Rear Projection...
Aline blue grosshire
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Toshiba 50H72 50" Rear Projection...
I have an RCA 50 inch projection tv that all of a sudden looks like the picture is warped on the screen.I can not make screen adjustments with the remote to solve it.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jul 13, 2009 | Toshiba 50H72 50" Rear Projection...
Need resister
DIgikey should have it. It is a 2Ohm 1 watt resistor.
Feb 08, 2009 | Toshiba 50H72 50" Rear Projection...
I have a toshiba model 50h72 double vishion
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 12, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50h72
STK392-110 Convergence ICs you will need two of them. You can get replacement ICs with free instalation instrcutions at the following link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Toshiba 50H72 50" Rear Projection...
50H72
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba convergence issue model # 50H72
looks like this is your problem http://www.fixya.com/support/t348123-toshiba_50h72
Mar 22, 2008 | Toshiba 50H72 50" Rear Projection...
Convergence
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
STK392-010 replace with STK392-040
good luck
please mark the post with a fixya
Feb 24, 2008 | Samsung HC-P4752W 47" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
71 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
