SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
I had the same issue twice with a TH 42PWD5. turns out it was my UPS that was killing the switching power supply. Warranty covered it but when I removed the UPS not a single issue in 3 years.
SOURCE: broken glass - 42 panasonic th c42hd18
usually not very cost effective to replace the front screen. id say around 70% of what you paid for the tv.
SOURCE: my panasonic plasma tv model number th-42px77u
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
SOURCE: Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me.
Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
SOURCE: TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu at the left top corner or the display
window. It will make search easy. Some times, the ads attached with each posts
might help you to find the availability of spare parts. There are more than 625
posts to different brand TVs.
