Problem with Sony DAV-DX255 System
Getting an error display as
1 Solution
Getting an error display as "Push power protector" in my Sony Home theatre - DAV DZ777. what is the solution.
552 people viewed this problem
  • 1 person found this problem to be helpful.
  • 2 people are following this problem.
More Insights on Fixboard
1 Solution
This solution has been voted best by the Fixya Commnunity
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
Add your solution
Full Name
Top Sony Home Theater Systems Experts
David Dunn
  • Solutions: 8546
  • Level: 3
  • Achievements: 1
Shahid Electronics
  • Solutions: 10594
  • Level: 3
  • Achievements: 1
Muntejaya Ginting
  • Solutions: 10421
  • Level: 3
  • Achievements: 1
Expert Badge
Are you a Sony Home Theater System Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More DAV-DX255 System Related Problems
Unsolved Problems:
See all Sony DAV-DX255 System Problems
Loading... Loading...
