Question about GE Refrigerators
Hello i hava a GE Model#DSS25PFMDWW SER#RD216509 and the ice maker is not making any ice in our frige it has been 2 days since it stoped woking we took out the tray filled the ice chest and put the tray back and the ice never started to come out again how can we fix this problem please can you give some advice.
I defrosted the freezer and it worked fine thanks.
Posted on Jul 21, 2008
Ge profile refrigerator model pss26msrssmy ice maker is make a machine gun sound as it pumps water. Is this the pump or the ice maker?
there is no pump..usaly a sign of air in the lines wich usaly means the water tank inside the back of frige is leaking
Jan 12, 2014 | Refrigerators
GE fridge freezer profile
the fridge needs servicing....if you still have waranty use it.
Nov 12, 2007 | GE Profile PSI23NCR Side by Side...
Has stoped makeing ice and none of the door controles work. model SH205298
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice machine makes little bit of ice one day then it might be two days before it makes anymore
clean the condencer under frige.is the fan working good in the freezer. the ice maker heater could be bad ice maker gear could be bad
Dec 21, 2009 | Kenmore Refrigerators
I poured water into the icemaker and ice cubes are formed but will not be dumped into the empty tray of my ge profile
The icemaker is bad then . It will have to be replaced by removing 2 screws and a plug connector . Easily replaced . Make sure the icemaker is turned on though .
Aug 16, 2009 | Refrigerators
Fridge not cooling and making noise
MY GE ICE MAKER IS MAKING A LOUD NOISE, HOW DO I DISABLE THE UNIT BEFORE IT BURNS UP SOMETHING
Jul 13, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Where is the relay switch on this model
The start relay is on the side of the compressor below the refrigerator. There is a plastic cover that covers the wires going into compressor. When you get ready to check it lets check the windings inside the compressor also. You will need an OHM meter. Let me know, Sea Breeze
May 21, 2009 | GE Refrigerators
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Refrigerator Stoped making ice
the small pipe in side the freezer the one that supplies water to it, it builds ice in side, you can melt the ice by getting some hot water and a towel and wet the pipe with it intel ice melts , or you can unplug the frige with the door open over night.first solution is better.
Dec 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
