Question about Xerox DOCUMATE 510 Flatbed Scanner
Xerox 510 will not scan from ADF
Hi we have a new Documate 510. It scans fine from the flatbed, but will not scan at all from the ADF. when we go to scan and select the ADF nothing happens. It doesn't even make a noise like it is thinking of it, though the ready light is on. How can this be fixed. We've tried everything.
  • itschelsea10 Sep 13, 2008
    Same problem as above.
  • chris_karas Apr 21, 2009
    scanner only scans one page at a time using ADF - not the 10 pages per minute as it should
    Problem Solver:
  • 12 Answers
If it is new, and not assuming there is a hardware problem with the scanner (some fault), might be a software problem. If the scanned image from the flabed is OK the drivers would be installed properly. You do not say which software you are using but when you have a "Professional" documentscanner and intend to use it for "production" scanning you need proper software also, To scan, to mix documents, rearrange pages, auto remove blank pages, deskew, produce small PDFs even when scanning color and so on. Look at PixEdit - it will do the job for you.
Posted on Aug 21, 2009
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Where can I get ADF parts?
eBay: Find Xerox Documate 510 Workgroup Scanner w/ADF - PARTS UNIT in the Computers Networking , Scanners , Standard Flatbed Scanners ...
Dec 03, 2009 | Canon imageCLASS D880 All-In-One Laser...
I need to scan both sides of a document. How is
How to fix my Personal Computer when it show blue page , I want to know what cause it is.
Nov 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
I had a paper jam in my scanner a few months ago. I got the paper jam out. But now, when I try to scan from the ADF, the paper goes through fast and then stops half way through and an error comes up in...
There are sensors under the ADF which sense the movement of paper and the presense of paper. Either they are jammed or faulty. Clean them thoroughly.
S. Mohan
Jun 20, 2009 | Xerox DocuMate 510 Document Scanner
No paper message for ADF
I called Xerox and the technician told me the ADF cable was loose. I went home readjusted the ADF cable and now it works like a champ.
Jan 19, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
My Xerox Documate 510 adds a line from top to bottom down each scanned document. The line only appears when something is fed into the paper feeder and does not happen when scanned single sheet at a time on...
you probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Jan 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Problem with the adf documate 510
Check the adf pad assembly. It is the small grey pad inside the top cover. One replacement pad should have come with your scanner. Mine was doing the same thing, when I replaced the pad, it worked like new.
Jul 28, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Color streaks on ADF feed.
Sounds like a dirty seal glass.
The small srtip of glass on the left side of the scanner.
Clean it well.
If there is no streak when scanning on the flad bed portion, then there is most likely a small almost non visible contaminant on the seal glass.
Use a regular piece of 20 pound paper crumpled with some glass cleaner or alcohol and clean that glass thorughly
Jan 10, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Document not moving all the way thru ADF.
The roller and retard pad need replaced. They are simply worn.
Oct 19, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DOCUMATE 510 Flatbed Scanner Logo
447 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
