Question about Insignia NS- 27" TV27 TV
Volume Hi, My volume all of a sudden just stopped working. (Insignia 26 or 27"-few mths old)I can move the vol. control but it wont make a sound. I don't know if I pressed something on the remote. Please help.
  • robertdtapia Jan 28, 2009
    my insignia 26" sound stopped working. the tv would make this high pitched static noise. i could turn it off and back on and it would return to normal. Now, there is no sound on the TV.
  • Anonymous Feb 21, 2009
    the volume on my Insignia 28" TV just stopped working. I don't see a button 'DISP' on my remote?
Sounds like it's locked. Either hold the remote control "DISP" down for 3 seconds, or press it repeatedly about 10 times & it'll unlock.
Posted on Oct 01, 2008
Mitubishi WD65731 lost sound and I cannot control the volume on the TV or with Remote
check your cables and make sure the vol- button isnt physically stuck
Jul 13, 2015 | Mitsubishi WD65731
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
MY OLD INSIGNIA SPEAKERS (WITHA SUB-WOOFER) WENT UP SO I GOT A SIMPLE 2 SPEAKER INSIGNIA 2.0 POWERED SPEAKERS. NOW I CANT GET ANY SOUND. ANY THOUGHTS?
1. Try looking in the taskbar of the Windows screen and selecting the volume control ( a speaker icon) check the mixer see if the volume is not muted or in the "0" position
2.Check the "input port on the sound card where you connected the new speaker assembly.
3. Check the volume control knob on the speaker assembly to see if it is not in the off or lowest volume position.
4. Check the new speaker by connecting them to another computer that has the sound already on and working this will let you know that the speaker assembly is good.
6. check the sound card drivers to the internal sound card that is on the mother board if this is where your sound card is located. Use the "manager" to see if it is working properly. If not then do a "reinstall of the sound card drivers or use the "update feature in the hardware window for the sound card to install the latest version of sound card drivers.
I hope this helps. Have a great day!
Sep 25, 2010 | Insignia 2.0 Speaker System (2-Piece)
Low volume sound
your better check the volume control of your computer....i mean the vol contrl on the start menu-accessories........
Feb 02, 2010 | Insignia 2.1 Speaker System (3-Piece)
Insignia TV suddenly no sound
Go into the SOUND section of the menu. Find the TV Speaker out option and make sure its on.
Make sure the VOLUME is not set to zero !!
Feb 23, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Purchased your A/V reciever NS-R5101 yesterday. When I removed it from the carton I noticed that Master Volume Dial has no stops in either direction. Dial turns continually in clockwise and counter...
This type of volume control is often called an encoder. Basically it is a control for an electronic volume control chip. Rather than a vairable resistor like the "old fashioned" volume controls, this one basically is a rotary on/off switch. As you turn it the internal fingers pass over copper bars causing quick on/off sequences. These are interpreted as vol up and vol down.
Realise that this is an over simplification, but is essentially how it works. Your unit is fine.
Dan
Jul 29, 2008 | Insignia Audio Players & Recorders
DE1103
you should try pushing the reset hole with a unfolded paper clip, or leaving the batteries out of the unit overnight
Jun 11, 2008 | Kaito KA1103 SW/FM/AM Radio
Sound
Push the volume button and it will switch from Vol. to Nav. Mix, this will allow you to turn down the navigation volume.
Mar 28, 2008 | Alpine PowerNav NVE-N852A GPS Receiver
Insignia NS- 27" TV27 TV Logo
132 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
