Question about Sony Ericsson P1i
Can't open web pages in WLAN mode
Web browser does not open in WLAN mode whereas the same work well through GPRS.
i tried every possible solution - assigning IP, DNS, changing the power settings etc. but nothing worked for me.
can someone help me with it as i have to use wi-fi pretty often at cafes, restaurants etc.
  • 1 more comment
  • kkoommss Jul 17, 2008
    Had the same problem but some how fixed it. WLAN connected blue ball displayed but the page didn't open.. well this is what i did and it worked...
    I went to my router and opened the section for wireless access point or the access control. I dint turn on the access control mine is still an open network but the was a list displaying available access cards connected to the router..in that my laptop and my P1i showed and i added them to the access control list( even though i didn't check the box to turn access control..wiered) but it worked and im browsing.. now when i check the connected devices ..it shows the P1i tooo.. soo the fix is in the router...none other solutions abt router worked except this one AND i use operamini and not the default browser.. .. am I A GENIUS?
  • Anonymous Jul 30, 2008
    i have a problem after the wlan is connected web pages couldn't open and this message is displayed for me " couldn't locate remote server"
  • tuliopacheco Aug 15, 2008
    when I go to linksys neteork, and go to Internet explorer or opera there is a error messege: [the page cannot be displyed. I use my modem and router and everything works fine. I am truing to find out if I can surt the web with a WLAN adapter hooked up to my home computer.
    Any help?
    thanks.
Posted on Jul 17, 2008
How to Chang the password of wlan
With most wireless routers you can go to their default IP address in your web browser. Open up Firefox, Internet Explorer, or the browser of your choosing and type in to the URL bar:
192.168.0.1
This is the most common IP address for wireless routers and should bring you to the wlan's configuration page. Enter your wireless routers default password and then look around in the configuration for where you can change your password (usually on the first page that pops up).
If you can tell me the exact WLAN you have, I can further assist you and tell you exactly where in that configuration page you can change your password.
Please be sure to be connected to your wireless router before attempting to navigate to 192.168.0.1 as this method will not work if you're connected to another network!
Jul 24, 2011 | Computers & Internet
Failed to connect to the internet thr wi-fi
f Active Standby is activated on your Cell, your WLAN connection status is always visible from standby mode. The bottom line of the screen shows your WLAN status. If there are no wireless networks in the area, you'll see the message 'No WLAN network found'. If you're near a WLAN that you're not connected to, you'll see the message 'WLAN name found'.
To log on to this network, simply highlight the WLAN status line and press the centre selection key. You'll see three options:
  • Start Web browsing
  • Search for WLAN
  • Switch WLAN scan off
If the WLAN has detected then cell will open, unprotected network (and needs no passcode to access) then simply highlight Start Web browsing and press the centre selection key to go to your Bookmarks page and start browsing the web.
Hope this helps
Jan 17, 2011 | Cell Phones
I cant get internet on my n97 nokia phone so i want you to help me with that.
Hi
Check the priority of your internet connection access points under settings>connectivity>destinations. By default the WLAN gets higher priority. Therefore, when there is a known WLAN available, the phone will connect through it before any GPRS or 3G connection.
Also, there are some reports of conflict between the WLAN & GPRS/3G connection & the web browser gets this conflict & present the "Invalid server name". The solution of this is to close your browser & restart your phone. Also, removing your WLAN, GPRS, or 3G setting & redefining them may help.
Good luck.
Aug 26, 2010 | Nokia N97 Cell Phone
Iam using blackberry curve 8900 and im able to access airtel gprs through opera mini...bt through main browser i am not able ao access it can n e 1 thr sort out ma prblm plzzzz.....
Hi, in BlackBerry Curve 8900, there're actually two browsers available, only if the BlackBerry Internet service is active.
One of the browser is meant for accessing via WLan. & the other for BIS-B service. + an additional Browser relative to the Network provider will also be available.
So check whether the WLan browser is not accessed.
Your BIS-B service might be active since you're getting the network connection in Opera mini.
Please check which browser is accessed & then try.
Regards
Vineeth K.
Aug 05, 2010 | Cell Phones
How to activate my gprs,model i9 sciphone
enter menu, then web browser, then browser settings and select gprs...
May 26, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Web won't load, when i click web the screen goes black and takes me to the main menu .
Have you made the initial settings to access the web? Have you got GPRS activated? Alternatively, are you accessing the web thru Wlan? The settings of Wlan?
Aug 02, 2009 | Nokia N95 Cellular Phone
Web Browser
its not you browser it a connection problem ...if you are using net through GPRS then once again get the GPRS settings for your cellphone.. or if it is wifi then check the connection settings properly..
Jul 04, 2009 | Nokia N81
What is the correct data or GPRS info for my cect i9 phone?
Hi! Your GPRS or data packet service is currently not activated and thats the reason you can't access internet. So contact at&t and get your gprs service activated first and if it is activated then under your phone connection settings input the following settings-
GPRS Settings:
Settings Name: Cingular Wireless Internet Express
Home Page: http://device:home or http://device.home
Session Mode: Permanent
Connection Security: On
APN: wap.cingular (lower case)
PDP_Type: IP
Gateway IP Address: 66.209.11.61
Port: 9201
Authentication Type: Secure
Login Type: Automatic
User Name: WAP@CINGULARGPRS.COM
(All upper case)
Password: CINGULAR1
(All upper case)
MMS Settings:
Service Name: MMS
Server Name (mmsc): http://mmsc.cingular.com
Web Session Name: MMS
Leave user name & password field blank
Also if above settings don't work then try-
148.233.239.24
Port 3128
or
APN: proxy
UserId: leave blank
Password: Leave blank
Browser settings:
IP: 10.250.250.250
Port 9203
home page: http://home
with rest things same
Dec 27, 2008 | Cell Phones
Psp
You can go online with the PSP system and browse the Internet. To start browsing the Internet
  1. Check your PSP system set up:
    • Infrastructure Mode
      Make sure your PSP system is set up for Infrastructure mode.
      See Setting up Infrastructure mode for details.
    • Internet Connection
      Make sure you have an internet connection and your PSP is within range of the wireless access point (or hotspot).
      PSP®online connectivity requires internet service and network devices, suchas a DSL or cable modem and a wireless router - for example, a Wi-Fihotspot at a café or a wireless local area network (WLAN) in your home.
    • System Software
      Make sure you've got the latest System Software.
      Requires PSP system software version of 2.0 or higher. Visit PSP System Software Update to download and install the most recent version.
    • WLAN switch
      Make sure the WLAN switch on the left side of the PSP system is turned on so that the PSP system can connect to the internet.
  2. In the XMB™ home menu select icn_network.gif (Network) > icn_www.gif (Internet Browser) and press the icn_btnx_color.gif button.
  3. Use the up and down buttons to select the address bar and then press the icn_btnx_color.gif button to display the on-screen keyboard.
  4. Enter the address for the web page you want to display, select Enter and then press the icn_btnx_color.gif button.
    For more information, see Using the On-screen Keyboard.
  5. Select a connection and press the icn_btnx_color.gif button.
  6. The web page is displayed.
  7. To hide the on-screen menu, press the icn_btntriangle_color.gif button.
To close the Internet connection:
  1. With a web page on the screen, press the icn_btncircle_color.gif button.
  2. Select Yes and press the icn_btnx_color.gif button.
  3. The internet browser will close.
If you have issues connecting to the Internet, you may wish to troubleshoot your Infrastructure mode connection.
Sep 14, 2008 | Sony PlayStation Portable (PSP) Console
Wlan key for netopia 2247NWG-VGX WIRELESS ROUTER
Hi there!
I believe the WLAN key can be found at your router's set-up page or web ui. Do you know how to access it? If Not, then try to access this link and hopefully this will help you to find it..
http://www.netopia.com/support/hardware/technotes/NQG_112.html
May 04, 2008 | Netopia 2247NWG-VGx Wireless Router...
Sony Ericsson P1i Logo
254 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
