Question about Bernina Artista 180
Connection problem with computer to sewing machine and reader/writer
I have the new Designer Plus software V5 and Windows XP. I can't establish a connection from the computer to the reader/writer device or the machine. I have two serial comports on the back of my computer. I first disconnected and uninstalled my scanner as I read that it may cause an interference. I tried both comports but get either of these messages depending on which comport I choose. "The serial port is engaged." or "There is no link to the serial port." I tried a Keyspan connection device for a USB connection and got the same messages.
  • mike9965 Aug 06, 2008
    I'm having the same problem. My error message says that the serial port has the wrong echo. Have tried changing the port settings in Hardware Manager--but have not found the right combination--parity, stop bits, baud rate, etc. Bernina says that they are no longer supporting the Artista Designer version 3. If I update the software, then my 180 will not be compatible with newer software. If someone could only tell me how to set up the serial port variables, I would be ok.
    mlcarter@cableone.net in Meridian, Idaho
  • judymom59 Dec 08, 2008
    I have tried connecting to 3 different computers in my house, using 2 different cables and everytime I get the same messages, " Seriel port is engaged" and No link to seriel port. The no link message is when I try different com ports so I am assuming they are the wrong ones but nothing has worked!
MY MACHINE IS A BERNINA ARTISTA 730 EMBROIDERY MACHINE WHICH IS NEW TO ME HENCE THE PROBLEM,I ALSO HAVE A 180 MODEL WHICH I CAN MANAGE QUITE WELL.
PAMELA
Posted on Oct 23, 2008
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Posted on Oct 03, 2008
I have a bouth a new computer with windows7. I have installed all my 4D Embroidery Extra and 4D Reader Writer. However I am unable to call up designs on my reader writer. Do I have to install a new...
I had a similiar problem, but I have the Designer SE. In Windows 7 there is an option to run it in a compability mode, so I had to set my program to run in XP 32 bit mode for the 4D software to run. I don't know if it will help, but if the software worked in XP, this should do the trick.
Dec 26, 2010 | Husqvarna Designer I
I have not used my Husqvarna reader/writer for a while. I put the program on windows 98 because I bought a new Mac, and it says the reader/writer cannot be found. Therefore I cannot get my embroidery on...
You might just need new drivers for the reader/writer. Try the Husqvarna website first, or else do an internet search for "Husqvarna Reader/Writer drivers" or something similar. Is the reader/writer a USB or serial connection? You are going to have problems if it is serial and I am not sure there is a solution, but USB connection should definitely be able to get working.
Nov 14, 2010 | Husqvarna Designer I
4D d-card reader/writer - seems to be installed but not working
I have been having the same problem. I was told that the 4-d software is not compatible with Windows 7.
Mar 23, 2010 | Husqvarna Designer I
I have a windows XP computer and I am trying to get to read r/w
Being as you have xp looks like you will have to go to viking site and download a patch to make it compatable, I have a Janome and when we upgraded the computer I had to go to the janome site and download upgrade, the same would apply to the customizing software I would think.
Nov 24, 2009 | Husqvarna Viking 1
I need the driver installation for my reader/writer d-card
Drivers are on the installation disk. 3D will have it on cd#1 and 4D on the dvd. With the disk in the drive, plug the dCard reader/writer in and use the "add new hardware" wizard to allow the drivers to install automatically. Now,either repeat this for each usb port or remember to always plug in to the same port.
Sep 02, 2009 | Husqvarna Designer I
Viking Rose can't install System 5 software
You may be able to find an old computer with Windows 95 or 98. Make sure that it also has a parallel port for the older R/W boxes.
You may also find that the 4D Embroidery package will do what you wish to do and it is under $400. 4D Embroidery Extra is the $700 package.
If you only want to put existing designs onto the card with no manipulation, you can get the Reader/Writer kit, $199 MSRP that includes Organizer which will allow you to load 1 design to your card at a time.
Unfortunately, System 5 was replaced by VIP which was replaced by 3D which was replaced by 4D. I don't think that system 5 will run on anything newer than Windows 98.
Apr 03, 2009 | Husqvarna Designer I
Dongle issue
The Designer SE software does not use a dongle. If you are attempting a "Smart Update" on the Designer SE and it asks if you use a dongle, just say no and the update on the machine will run.
If you have 3D or 4D software, it uses the dongle and it will be USB. Download the latest driver for your software from the Husqvarna Viking website. The link is through the homepage at Husqvarnaviking.com/us . Click links on the left side of the screen for 4D Software, Help & Updates, and Other Useful Software at the bottom of the page. This will have the latest 3D driver. 4D will require the latest update to the software and a firmware upgrade to the dongle. Run Smart Update on the software and then get the firmware update that is directly below the 3D HASP driver on the Other Useful Software page.
Nov 09, 2007 | Husqvarna Designer I
Sewing Machines Logo
758 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
