Question about InFocus Lamp Projector Lamp for LP240 [ SP-LAMP-005
Infocus LP280 When the projector is turned on, the fans are on for just several seconds and then shut off. The light never comes on. Is this a safety feature indicating a blown lamp? I get no resistance ready when I check across the bulb filament.
Not mine but a friend's. Found a manual online, read it, fixed it. One must wait a while when pushing those buttons. One must have patience and read the manual before crying "it don't work".
Posted on Jul 17, 2008
InFocus LP280 turns on then shortly turns itself off. Will not stay on.
There are 3 things that you should check.
1. The lamp
2. The firmware version. (the last is the "1.26E")
3. The power supply (may exibit oxidation in the ECA main board conector). And you need a technician to clean it.
Apr 08, 2010 | InFocus LP280 LCD Projector
Projector turns on for about 30 seconds then shuts down. the fan kicks up high, and led light flashes yellow for about 4 min until the fan shuts off. does not feel hot so overheating does not seem to be...
if the lamp lights and then shuts down, replace the lamp. it's at the end of it's life. to rule out overheating, blow the projector out with canned air. dust retains the heat that the projector is trying to expell. also see if all of the fans are working. if you do get an image for a short time, try to get into the menu to reset the settings to factory default. lastly, if all else fails, you have a ballast issue. unfortunately, infocus no longer sells parts for this model.
Nov 28, 2009 | InFocus LP 630 Multimedia Projector
How to Clean the lense on a Infocus LP280
outside- lint-free microfiber cloth and canned air. inside (projector)- canned air.
Nov 09, 2009 | InFocus LP280 Projector, Factory...
My infocus IN1 projector won't turn on anymore.
It may be the lamp is out. Normally a projector will try & fire the lamp 3-5 times then shut down with a different color light like amber or red. If the lamp doesn't light then it could be the lamp or perhaps the lamp ballast that starts the lamp has failed. A stuck fan also causes similar symptoms. There's 2-4 fans in the projector if one is stuck or bad it will turn off within 5 seconds or so after the lamp lights.
Does your lamp light at all? Are the lights a different color after it shuts down? Answers to these questions help figure out what's wrong though it's impossible to say for sure without looking at it. I service almost all Infocus projectors if you would like a quote please reply with your email address or write me at prmhelp@earthlink.net
Good Luck,
Jim
Jul 24, 2009 | InFocus Televison & Video
Infocus LP280 projector will shutdown itself
The Lamp cooling fan is not working or the fan speed control chip/circuit has failed. Do not run the projector until it is repaired as this condition rapidly destroys the lamp!! If the cause of the problem is simply the fan itself. It can quite easily be acquired and replaced by someone who is electro-mechanically savvy.
If the problem is on the main board (also very possible) it is substantially more difficult to repair and should only be done by someone who is an order of magnitude above just electro-mechanically savvy.
Also if the problem is in fact the main board an authorized service center would just replace it!
(hang on to your wallet)
Cheers
Feb 26, 2009 | InFocus LP280 Projector, Factory...
Infocus LP280 Shuts down
the lamp's quality is not good ,the lamp is too hot to work,
We Offer all the Original projector Lamps (bulb).Good quality good price.
Jerry Zhong (China)
Skype: hw998.com
E-mail: hw998.com@126.com
Aug 27, 2008 | InFocus Lamp Projector Lamp for LP240 [...
No Image
You may be hearing the color wheel turning. Make sure the lamp is installed correctly and lamp access door/plate is properly closed.
Jun 24, 2008 | InFocus Lamp Projector Lamp for LP240 [...
InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Mar 11, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Infocus x1a projector shuts down after 30 seconds - dust problem ??
There is a safety themostat inside the unit (looks like a silver button the approx size of a dime) that will shut the system down if you do not have adequate airflow. You can dis-assemble the projector by removing the screws on the bottom and rear of the housing and pressing in the plastic locking tabs inside the cover all around the perimeter but I would advise against this unless you are comfortable with delicate nature of the projector.
Dec 17, 2007 | InFocus X1 Multimedia Projector
204 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
