Question about Epson TM-U220 Matrix Printer
Printer not available
I installed the driver ADP 4.02E first and the printer was "Not Available" after that I uninstalled the driver and tried with a driver from epson-pos.com (ADP 4.02aE but the printer is always "Not Available"
I connected the printer after the installation, modify the DIPS to put the busy condition "Receive buffer full" as i see in the install guide
But it still not work...
Thanks for help
I'm Still trying to figure it out also, I have the same exact problem of the printer saying "Not Available" I'm going to go ahead and install an older driver for this and see if that helps at all.
Posted on Aug 13, 2008
Thanks for help
Posted on Aug 09, 2008
How to replace in tray on hp 882c?
If you are again driver installation then first you check it driver backup available or not. If available then ok or it not then you download first then re-installed it. Or if you are now printer add then old driver uninstalled and new printer installed it.
I share a link please visit and follow step by step instruction.
A> If you are uninstalled process then go to control panel and select add removed programs and search printer driver name and select and removed it.
B> Installation Process- first old driver uninstalled and new driver setup double click and follow instruction and full installed it.
More info visit it:-
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&product=59305
Thanks,
HP Printer Support
May 30, 2014 | HP DeskJet 882c InkJet Printer
When I log in it say's RPC server not available and restarts it's self
First you can uninstall your printer driver then restart your pc. After that install your printer driver and also need restart your computer. Now try it. Thanks a lot
Nov 09, 2012 | Office Equipment & Supplies
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
Drirves for win 7 for x1155
The Windows Vista drivers work with Windows 7 for this printer, the drivers can be downloaded here.
Please follow these instructions when installing:
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Note: Before proceeding with your driver installation we suggest you make sure you are installing the latest version available and for the appropriate model/revision and Operating System. We strongly suggest following 'readme' instructions for installing drivers when available. Often restarting your system will be necessary for the new driver to become active and start functioning properly.
Mar 03, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Installer of hp 1410
The 1410 drivers are available on the HP website, (www.hp.com) http://h10025.www1.hp.com/ewfrf/wc/product?product=458978&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Drivers are available for all Operating Systems, Windows 2000 up to Windows 7, Mac OSx and Linux (although I'm pretty sure that the right drivers will be available in Linux via the CuPs system)
General rule of thumb. Install the drivers BEFORE you plug the printer into the computer (via usb).
If you've already connected it and windows has installed the default windows drivers - this may be enough for your needs, but if you're having problems, you'll have to disconnect the printer from the computer and uninstall the drivers.
Go to to start -> Control Panel and then: Add or remove programs (for XP, windows 2000) or Programs (if you're using Windows 7) Find the HP Printer driver in the list of installed programs and select uninstall.
If the driver isn't listed, don't worry, simply download the drivers from the Hp site, double click on the program to start the install process and connect the printer to the computer when it asks. (with most drivers installs just double click to run, read and follow the instructions, mostly it's a case of just pressing "next" until it starts installing.
Remember when you connect the printer to turn it on (button at the front that glows green when you turn the printer on) - you'd be suprised how many people forget that part!
Feb 28, 2011 | HP PSC 1410v All-in-One Printer
I have lost the CD to my Lexmark X8350 and need to install on a new laptop. I have trired the links to lexmark Driver Downloads but the printer still is not working
Try to uninstall any existing Lexmark X8350 printer software from your computer. Refer to this article on How to Uninstall Lexmark Printers. Reboot your laptop when prompted. To reinstall, use the updated driver available at http://bit.ly/eO4Y77. Select your operating system to download the driver. NOTE: Use the Vista driver in Windows 7.
Jan 17, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
I am unable to uninstall my lexmark printer driver from my laptop... i was trying to install the new driver and it refused to over ride the previous installed driver and then i did a system restore and now...
Please try this. Run the install disk/web installer -> select Support -> select Uninstall. If Uninstall initializes, reboot your computer after the process finishes. Then reinstall using the new driver.
If the "Uninstall" option is not available, it would be best to contact Lexmark technical support for assistance.
NOTE: MAKE SURE TO USE THE PRINTER DRIVER COMPATIBLE WITH YOUR COMPUTER'S OPERATING SYSTEM.
Nov 11, 2010 | Lexmark X2550 All-In-One Printer
INSTALLATION OF LEXMARK X5250 PRINTER ON WINDOWS 7
Hi, Lexmark printer drivers can be found on this site: Driver Update Software for XP Vista 7 8. Have a nice day
Thomas
Apr 09, 2010 | Lexmark X5250 All-In-One InkJet Printer
X4530 "communication not available" with laptop
I already experience it ..it becuase of the driver..I think you have 2 or more printer driver installed on your computer right??
you need to uninstall all exisiting driver and install again the printer driver...
and then..
after installing the driver
go to >programs
>printer and faxes
right click the printer icon ..
select used printer as default printer..
and right again..and select >use printer online..
Thank you for using FIXYA..
please a rate ..if it solve your problem..
good luck.
and thank you for choosing lexmark.
May 22, 2009 | Lexmark X4530 InkJet Printer
HP OJP L7580 and VISTA no SCANNER available
You may want to try the full install before spending more time troubleshooting. It's a 300mb download (!), but it might be worth a try.
You don't say what software you're trying to use to scan, either; you may wish to try another one. If you want to experiment, you can download a free photo editing package that won't take over all your preferences for files -- check out portableapps.com and look for GIMP.
I've got an older HP printer, a PSC 1610, and it took me something like *seven* times installing it on Vista before it worked right. It turns out there's the regular uninstall, and then there's a super uninstall, and then there's a super duper uninstall, etc -- something like seven different uninstallation procedures, which is just insane.
HP's drivers and cruddy software convinced me to never by another one. It's a shame -- the company made some laser printers 15 years ago that are still working perfectly.
Jan 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Epson TM-U220 Matrix Printer Logo
1,428 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
