Question about Konica Minolta magicolor 2400 Laser Printer
Konica Minolta Magiccolor 2350 Laser Printer
I am trying to change a toner cartridge. There was a message several days ago that said toner was low, replace cartridge. I have a message on the printer that says "black empty replace?" I select, then a message says "cannot rotate cartridge." If I select that, it goes back to "black empty replace? and so on.
Please help. Thank you.
The same problem about the tab on the door breaking off. This eliminated the carosel from rotating. Well the tech support directed me wrong and sent me Mother boards and skematics to tear down the and open the whole unit. It never went back correctly so never worked again. I only needed to fix the door tab all along. Now I have a broken Konica Minolta with $600 in unused wasted cartiages. I should buy a 2350 that works then I'll be set with bone yard parts from the other lousey 2350
Posted on Jan 06, 2010
When the front door is open, it locks the 4 cartridges so they can not move. The tab is flimsy & I broke mine on the second or third change. It pushes on a mechanical switch just above the toner port. If you broke the tip of the tab off, you can use a drywall screw inserted into the Mechanical switch. when the door closes the bigger part of the tab will push the screw against the switch,
Posted on Aug 26, 2008
Toner not insatlled magiccolor 4690
Remove a toner cartridge and verify a home position sensor or other components associated.If the cartridge is refill change the chip.
Dec 21, 2013 | Konica Minolta Magicolor 4690MF...
Magiccolor 2350. Paper jamed(paper end only)in
Kindly open the delivery door and back side of the printer. Check the space between metalic roller and the plastic with the help of a pin or something thin like ruler. Probably a pin or stappler might be stuck there just remove it. your printer will work fine. Secondly check that if any plastic is burnt or melt over there if so then use something rough to make it plain.
Feb 17, 2010 | Konica Minolta magicolor 2400 Laser...
Install konica minolta magiccolor 2400w printer without software?
Hallo,
I have a Konica-Minolta Magiccolor 2400 W. It wasn't used very often roughly less than 150 pages in 2 or 3 years. So I do not believe that I reached the capacity of this device. Now it says the black tomer is empty and need to be replaced. If one have a look at it: it is without any free place at the roll. So there must be nough tomer in it.
Please is there anybody who can provide an idea how I can set the information of this toner to zero again?
Thanks for your kind assistance.
aussi-dingo
Oct 16, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
FATAL ERROR
your printer is laser printer change toner cartridge right,
you may try
1) Open the front door and remove the toner cartridge.
2) you will see a small round hole near the colour toner cartridge
3) hold a screwdriver in that hole and the carousel will rotate freely. 4) Move the carousel round and remove each one of three cartridges at a time.
set back all cartridge close door.
Jan 29, 2009 | Konica Minolta magicolor 2300DL Laser...
I have a magicolor 2350. i'm trying to replace printer cartridges. i get "cannot rotate" error messages.
Sounds like something is in the way, whether it be a chip, paper. It is possible that one of the toners is not seated properly.
Open the cover take out the drum and inspect. Take out the toner that is on top and put back in.
Nov 26, 2008 | Konica Minolta magicolor 2400 Laser...
Need Override for Low Toner Message Minolta QMS 2300
It depends on the model. The 2300 series using a mechanical mirror on the cartridge itself. A tab needs to be moved the mirror slid back to home. The 2400 series & newer uses an IC that you need to replace. when you buy your toner to refill the cartridge make sure you get the IC with it. Russell
Aug 21, 2008 | Minolta magicolor 2350 Laser Printer
Question about mc 2350 cartridge
I just got done replacing my toner.  You'll need to change toner and most likely all of them. There is no other solution.  I refill mine by buying the bottle toners.  It can be messy and you'll need to take some parts off the cartridge to get to the opening plug and reset the lever so that the printer knows the cartridge is full.  It is cheaper than buying a toner. The cartridge has a life of about three refills.  Anyway hope this answers your problem.
Aug 07, 2008 | Minolta magicolor 2350 Laser Printer
Konica minolta magiccolor 2430 dl
Under Quality Tab you have the option for B/W printing.
Nov 29, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
694 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
