Question about Asrock K7VM4 Motherboard
Monitor wont power up after comp initial boot?
Hi there Briefly, my Monitor wont power up after the compts initial boot? Have tried the computer on three different monitors and the same applies. Can't see anything to be able to check bios etc. Any ideas are gratefully accepted. Thanks heaps Greg
  • 983 Answers
Hi.....
you will face this kind of display problem if the video adapter IC(integrated circuit ) is dead or if it is getting over heated in the short time in the motherboard ...
you just have to do is you must replace that video adapter IC ...
just contact the motherboard technician and get that IC replaced ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 16, 2008
When I boot my computer My HF237 monitor will briefly show the page then go dark. How can I diagnos the problem?
This is usually an issue with a failing capacitor. I replace them in mine often. In the monitor, on the power supply will be several capacitors (caps). Look for the tops to be domed these are bad. Try a site called badcaps if you are game to replace these.
A soldering station after shipping can be as low as $32 or so.
Oct 09, 2014 | Hannspree HF237HPB 23 inch LCD Monitor
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
No video image on LCD but OSD works
Sounds like you may have a bad video cale or a dmaged or bentpin in the connector, remove the cable from the monitor and look at the pins on the connector
Dec 14, 2009 | Philips 170S4FG 17" LCD Monitor
The led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or longer, Tried with changing...
Make sure that your computer isn't going into Standby or Hibernate mode. You can test this by briefly pressing the power button and wait to see if the screen comes back on.
Oct 26, 2009 | Samsung 943NW Monitor
Sometimes the picture on this monitor used to fade out to all black when my comp was idle but blocked from going standby. and recently it just quit working. when i power up my comp, the monitor gets all...
first u have to chk whether the screen has that kind of a colour in BIOS> if it has its a monitor issue> if not it can either be the video card that u use> or else the graphics chip on ur computer motherboard>
u can still try Reseating RAm and CMOS on ur motherboard then chek if ur computer boots with display
Oct 09, 2009 | Sony SDM-HS73P 17" LCD Monitor
MY COMPUTER COULD NO LONGER BOOT UP AFTER POWER FLUCTUATION
Check the power supply, sounds like it isn't getting enough electricity out the the PC components.
Jun 09, 2009 | Intel D845PEBT2 Motherboard
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Initially disk boot failure now White screen but runs in oter mon
Try checking inside the computer for loose wiring near where the power supply box plugs into the motherboard, make sure that you turn the computer off and remove it from the outlet before opening it. While the computer is open, check all of the leads going into the motherboard are pushed in gently but firmly. Remove the RAM clean it with a soft paintbrush and then return them to there slots ensuring that they are seated correctly. Do the same with the graphics card and sound card if you have them in PCI slots or AGP slot returning them correctly into thier slots.
Put everything back together and before powering back on make sure that the power leads going into your PC and into your monitor have not been damaged in any way. Reboot your computer and try again. If you still get a shock or your computer does not boot properly then you may need to change the power supply box.
I hope this helps
Dec 15, 2008 | Acer AL1717 17" LCD Monitor
Computer wont power up after graphics card inserted
Remove the video card.
Boot the system and go into the BIOS
Set the onboard video to either auto or off, or in some cases you can change priority
Turn off the computer, reinstall the video card and give it a try.
Sep 28, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
I suspect the problem is with the monitor itself. I have had the same problem. I reported it to Dell and they sent me a new monitor within a few days the problem resurfaced again on the new monitor. They have since sent me a new monitor and the problem has disappeared. The Dell customer service people sounded rather cagy to me when I suggested that this was a problem endemic to this model. The replacement monitor that I have had a sticker on the box that read "refurbished". This is a rather new model of monitor to already be into selling "refurbished" models. If you are still under warranty I suggest you call them. And even if you aren't, call them anyway. I sense that they know about this problem.
Oct 23, 2006 | Philips 105S51 15" CRT Monitor
Asrock K7VM4 Motherboard Logo
99 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
