Akai 32" had pluged into surge protector and it went out and also my stereo i put fuse in stereo and its find i want to check in back of tv to see if that is only problem with tv. but i see sticker stating to only have professional open. Is it safe for me to open and see without having to spen all that money for a possible fuse replacement. Thanks in advance
  • rightarm1 Jul 16, 2008
    i have the akai kco1-b2 and i can get it to come on but it wont go off no signal and whn i get it off that screen which is blue it goes tothe video menu with contrast as the first guide and advance picture adjust. and button i hit it only goes between those to screen which or blue. thanx in advace
  • 2,326 Answers
If you do not have any light on the front LED, is more likely that the fuse is defective.
You can open the TV if it's out of warranty. Make sure that the TV is unplug from the AC line.
The fuse is under the heatsink and it might be cover with a black heatshrink, so in order to check it and replace it you will have to unsolder it from the power supply assembly and solder back in.
akai 32
Posted on Jul 16, 2008
  • Jaime Hernandez Jul 16, 2008
    If you still see some signs of life on the screen, it means that there could be something else wrong in the main board not the power supply.
    If there was a power surge is more likely that it damaged the main board because the power supply is not well regulated to control the output voltage to the main board and other circuitry.
    Let me know if you need further assistance.
My stereo just quit on me there was bad weather but it was on one of those power surge cords it is a pioneer stereo fm-am digital synthesizer tuner
If it was plugged into a surge protector, check the surge protector warranty. There are A LOT of surge protectors that will cover damage to items plugged into them through their warranty system. I've had full home computers and TV's replaced by surge protector companies to avoid having a hit to homeowners insurance.
Aug 16, 2016 | Pioneer Audio Players & Recorders
Turn tv off left for weekend came home no red light no power
check the power cable and socket, and also check the fuse of the TV by opening the back panel.
Mar 19, 2015 | Televison & Video
I had to unplug my tv today (actually the TV is plugged into a surge protector, so I unplugged the surge protector.) when I plugged the surge protector back in the TV wouldn't go on (acts as if its...
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Jun 29, 2011 | Televison & Video
My electric went off yesterday and when it went back on my tv wouldnt turn on it was working fine before the power cut we have changed the fuse but still nothing is there anyway i can reset it to make it...
you said you changed the fuse. (inside the tv)double check to see if its blown agian if not. keep it unplugged for about 20 minutes to reset the surge protector onboard . if you have done all that the fuse didnt protect your tv from the surge and it gone. IF ITS CONNECTED TO A SURGE PROTECTOR unplug it from that and plug directly into the wall TRY THAT FIRST let me know if this works.
Mar 16, 2011 | Wharfedale Televison & Video
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
We didnt have a surge protector on our tv we purchased from home shopping net. and lihtning came in the line and i guess hit our tv can it be fixed or is it worth fixing price wise i hate to throw it away...
Look at the power supply module, most of them will have a surge protection devices (called MOV, same as used in common surge power strip but cannot handle big surge that power strip can handle) installed to protect minor surge, it should blow the fuse. Once MOV blown, it will more likely stay short circuit, if you put the new fuse in it will blow the fuse right away. You need to see if the MOVs blew up any sign of blown up components.
Nov 01, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
I also have an AKAI LCT3201AD that keeps turning off.
Bad power supply circuit....
Bad resistors, rectifiers, capacitors, or MOSFET devices. Your tv needs to be serviced, and for this problem it should be to expensive and should be 'sameday return. Its an easy fix.
Jun 12, 2009 | Akai LCT3215/26 32 in. LCD Television
Open Questions:
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
