Maytag MEW5527B Electric Single Oven Logo
Posted on Feb 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When pushing the button bake and broil the red light starts to blink on lock ? this happened after i woke 1 morning n noticed there was no time where the clock was, it was all dark n nothing worked, after a day r so i could finally set the clock, but cant bake cuz it goes on lock, please help
Sal De
Level 3:
  • Maytag Master 2,699 Answers
  • Posted on Feb 08, 2018
Sal  De
Maytag Master
Level 3:
Answers
2699
Questions
0
Helped
1003200
Points
8029
If the clock is blank it's bad and you have to change out the clock assy. if that's your model number MEW5527B it says your part is
WP74009198 and it's around 260 dollars but this must be an older wall oven because nobody has it in stock,you can go here,put your full model number in and go to control panel and look up your computer board or clock assy. same thing
https://www.searspartsdirect.com/model-number/MEW5527BAW/3048/0125300.html
5 Related Answers
Anonymous
  • 288 Answers
  • Posted on Nov 11, 2007
SOURCE: GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Anonymous
  • Posted on Dec 31, 2008
SOURCE: magic chef electric oven...went to
How do I replace the oven heating element in a Magic Chef oven?
Anonymous
  • 61 Answers
  • Posted on Nov 18, 2009
SOURCE: When I press the bake and broil button nothing
If you need a cheep part check out www.appliancepartssolutions.com
Anonymous
  • 1430 Answers
  • Posted on Apr 09, 2010
SOURCE: When I turn on my Maytag performa using the
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on May 20, 2010
SOURCE: Bake & Broil PB does not work
http://appliancejunk.com/ge/cookingproduct/31-20105.pdf
http://www.servicematters.com/maytag_library/docs/16000082.pdf
use these service manuals to troubleshoot
Why does only broil come on when i push the bake button?
Bake and broil elements can be tested with an ohm meter for continuity. There is a relay in control / clock for both bake and broil elements. If elements test good, then those relays need to be tested for voltage.
Sep 16, 2017 • Ovens
Door locked wont self clean
Turn off breaker for minute or so if no contact repair man mcro switch bad or out of position. Did he try to pull door right after candle. The motor takes time to clear the hook from the latch. If so he probly bent some thing in the mech that latches the door or on the switch plate that holds the micro switch
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
31helpful
3answers
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 • Ovens
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 • Ovens
3helpful
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 • Ovens
2answers
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
