Question about JVC KD-G210 CD Player
CD WONT EJECT PIN HOLE
CD WONT EJECT EVEN THO I USED A PAPERCLIP IN THE SMALL HOLE. I HAVE A DETACHABLE FACE.
THANKS
    Genius:
  • 2,028 Answers
If it's trying to eject you may need to use a small screwwdriver to lift up on the CD. This works when mine hangs up. If it's not trying to eject at all, then the little motor on the ejecting mechanism may have failed or come off track. I had to replace the original CD player about a year ago because of this. That's why I have the JVC now, and it seems that CD's started hanging up from day one with this radio.
Posted on Jul 16, 2008
I have a dell xps M1330. My 4 year old daughter somehow managed to get 2 cds inside the cd drive and now I can't get out. Need help! Thanks.
On the front face place of your CD player, next to the button you use to eject/open the CD caddy, you should see a very small hole. Using a paperclip, insert the paperclip and gently press in the paperclip. It should release the caddy.
Apr 03, 2011 | Dell XPS M1330 Notebook
My cd-rom door will not open, any ideas?
You can open "my computer", right click on the cd-rom drive and choose eject. In case the cd-rom didn't eject the disk is locked in the tray and you have to use the small hole near the eject button and a paper clip.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 03, 2011 | Computers & Internet
I put a cd in the player, and now it wont eject
Most players have a manual eject. You have to take the radio out of the dash then remove the face plate. There should be a pin hole or something somewhere to force the ejector. Normally it's a pin hole and you can insert a very small screw driver or a paperclip in and as you push it forces the ejector back causing the **** to come out once the **** is out far enough you can pull it out.
Nov 09, 2010 | 2004 Pontiac Grand Prix
Key of eject CD/RW on keyboard do not work..
hi there,
Try to find that little tiny hole on your cdrom's door and push a paperclip and hold it until it ejects. That's another way to eject the cdrom.
Hope this helps.
Thank you for using FixYa.
Aug 28, 2010 | Computers & Internet
CD in stuck in the computer and I can't get it out using the eject button. How do I get it to come out?
hi,
its too simple. you dont need to worry.. Check the front side of the CD ROM. you will find there one small hole. Now just take a thing, which is around the 4 to 6 inch (min is 4") long and can pass through that hole (for eg. take medium size U pin, and remove all bends and make it straight or long needle) Now insert this equipment in that hole and press. your ROM will eject...
Hope this has helped you ... Thanks....
Jul 19, 2010 | Computers & Internet
CD Drive not Recognized / Wont Eject CD
There is a small pinhole in the face of the dvd drive. Use a paperclip to poke into the hole. It will force an eject of the dvd drive. You can also explore the computer, right mouse click on the drive letter of the dvd drive, choose "eject"....
If it still will not eject, unplug the ribbon cable from the drive but keep the power plugged in, then press the eject button. If worse comes to worse, four small screws, and you can remove the shell of the drive exposing the dvd inside....
Good luck!!!!
-------------------please vote 4 thumbs up 4 me!!!!-----------
Apr 25, 2010 | Dell Dimension XPS 400 PC Desktop
DVD will not eject
To eject a disc.
  1. Use the eject option in the menu bar by selecting open from the drop down menu.
  2. Press the eject or F12 key on the keyboard.
  3. Open the drive face plate and insert the end of a paperclip into the small hole under the drive tray area. This will pop the tray open.
Hope this helps. Don't forget to vote or leave feedback, Thanks.
Feb 23, 2010 | Apple eMac G4 Desktop
Wont eject cd
there is a safety release in all disk drives take a paperclip and push it into the small hole on the face of the drive and the drive should pop open
May 12, 2009 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
Cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Feb 20, 2009 | Gateway MT3705 Notebook
Cd player
does the face come off the cd player detachable the little reset is behind the face and if u press that the cd will eject
Sep 16, 2008 | 1998 Ford Mustang
JVC KD-G210 CD Player Logo
295 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
