Question about Panasonic Computers & Internet
I have 3 panasonic 5500 registers. The main till, till one is working. The 2nd till keeps saying *printer busy* and the third till is saying *video busy* and printer busy. I can't print out reciepts for till 2 and 3 and i can't punch anything in on till 3 without an unreasonable delay. I have unpluged everything and plugged it back in. Turned everything off and than back on. I don't know what to do
SOURCE: PRINTER BUSY ?
i am having the same problems it says printer busy someone plz help
Posted on Dec 17, 2007
CMV9
  • 594 Answers
SOURCE: New ASUS PRO50Z laptop with
have you downloaded the right software? for vista. also try to print something from your notepad or wordpad or a website page see if it will print.
Posted on Aug 15, 2008
mickspaceNET
  • 115 Answers
SOURCE: printer busy/or error
Sounds like your machine is using DHCP, not a static IP address?
Print your network settings from the Printer, then try to Ping from a computer on the network.
Check the Network setting of the machine, make sure it is set to a fixed (static) IP Address.
If this is the problem, you can go into your PC printers port and change the port to the reassigned IP Address of the machine.
If you reinstall the drivers then you will have this installed twice, one will work one will not, so delete it from the printers folder before you reinstall before you reinstall
Posted on Oct 25, 2008
XeroxHelp
  • 4 Answers
SOURCE: HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Posted on Feb 17, 2009
  • 4 Answers
SOURCE: Philips CD240 2nd phone wont connect - keeps saying searching
Hi, I solved this issue this morning. What you cannot confuse here is that handset and base. To do the registration successfully, the both must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting". The above, however, works only if the Base is still functioning. In my case, sadly, the base was more likely dead (if I press any button on the base, i.e. answer phone etc., there is no response). Hence I went and bought a new cheap GAP compatible BINATONE 1800 Single at Comet (14.99). I then set up the base, put it in the registration mode as per the BINATONE instruction. Then on the Phillips CD240 handset and gone through the above registration procedure... and Voila! It worked. Now I have a brand new base that came with 1 handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good and they retained all the telephone numbers registered with the handset. The BINATONE base came with 12 months manufacturer's guarantee so I am sorted with the base problem for at least a year, which is nice. I hope this is helpful. Best, Ken
Posted on Jan 24, 2010
I can't get my cordless food set to register. Cannot receive calls or call out. Message says the device is not registered
Please use the below link and complete steps 1-4 before holding down the main base's LOCATOR button.
http://service.us.panasonic.com/OPERMANPDF/KXTG4221-MUL.pdf#page=21
Jun 04, 2014 | Panasonic KX-TGA421N Dect 6.0 Plus...
Hi , hope someone can help. I am having problems with my eclipse avn 5500 navigation system reading the disc. It keeps saying check disc. Its the original disc not a copy. I did disconnect the car...
When the eclipse was installed the owner registered a disk for security reasons..... when power is disconnected the only way to resolve it is put the registered disk in!
Sep 10, 2017 | Eclipse AVN5500 Car DVD Player
The register keeps freezing and then shuts off. it says that the till roll is not properly inserted although it is
Hi Leanne
check around the path that the paper goes through, look for any dust build up or small scraps of paper and blow out/remove and try again. Hope this helps.
Feb 17, 2013 | Computers & Internet
I have a panasonic cordless phone, model kx-tga820. for some reason both handsets now say that it is busy when i push the talk button. Our other phones are ok. Why?
If you get busy tone in your Panasonic KX-TGA820 cordless phone, it may be due to any one of the following reasons:
1)The called handset is in use.
2)The handset you are calling is too far from the base unit.
Check whether the base unit is not so far from the handset
3)There is no handset registered to the base unit matching the extension number you entered.
Try to re-register the handset to the base unit again, To know details regarding registering and re-registering, please refer page 38 of the manual, which you can download from the link given below
4)Other units are in use and the system is busy. Try again later.
Try to check whether the other units are not using your base unit
You can download manual for your phone from the following link for reference
http://service.us.panasonic.com/OPERMANPDF/KXTG8231.PDF
Please rate this solution
Rnj VINODKUMAR
Nov 10, 2009 | Panasonic Lands Phones
Kodak 5500 Fax won't connect
Most likely problem is your phone company is blocking it for some reason.
Apr 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Feb 03, 2009 | Philips Lands Phones
Keep getting message phot tray not engaged
This should not be a problem at all, that message only means that (as it says) the photo tray is not engaged, and so you are going to print on the main tray. This is meant as a warning, not as an error message, and it shouldn't be getting in your way of printing.
Nov 18, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Ink
Be sure you removed the little transparent protector strips from the new replacement cartridges, or they will not register correctly.
May 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Computers & Internet Logo
69 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
