WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN I SWITCH TO ANALOGUE THE PICTURE ETC IS FINE AND REMAINS SO.IF I SWITCH OFF POWER AND TURN BACK ON TO DIGITAL IT IS OK AGAIN BUT AFTER A FEW MINUTES FREEZES AGAIN AND REPEATS AS ABOVE. HELP PLEASE
  • 372 Answers
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Posted on Jul 16, 2008
Wharfedale LCD2010AF perfect sound but no picture just dark screen with fuzzy grey and black horizontal lines
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 12, 2016 | Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
42LG3000 LCD TV 2 Years old from Currys last 6 months taken up to 2 hours for full picture, excellent always after that time waiting, yesterday would not give perfect picture only white screen SKY sound ok...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
No technician can do more than this, he/she can do anything except.
Sep 07, 2017 | LG 42LC2D 42 in. LCD HDTV
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Frozen screen
sounds like the digital main board
Jul 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Samsung hd protector television
i have found the lamp will cause sound no picture but if the picture freezes could be dmd bd or digital bd going bad
Oct 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Picture disappears and changes to white screen
I am assuming that this is the nature of the fault and that it is repeatable. Does what you have described occurs every time you turn the damn thing on. You haven't said is whether or not there are changes in sound when the screen malfunctions or whether your unit plugs into a GPO or a black box which plugs into the GPO.However this only dictates the ease with which the faulty component is replaced What seems to be happening is that white level controls are setting to maximum gain. If the control is digital It is almost certainly due to dirty power. The sound level should also change if the power supply is the culprit. Spikes cause the gain on the control to ramp up or down erratically (change) on digital parameter controls. This resulting in bleeding for white levels and a change in the sound levels. Replace the power supply if possible. A cheap workaround can be made if my assumptions are correct and the main transformer is not faulty. Leave a post if you want more info
Aug 01, 2007 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
