Question about Epson Stylus CX4800 All-In-One InkJet Printer
Printer Does not work.Scans just fine,but the printer just does not work.Any suggestions?
  • mgrise1 Jul 19, 2008
    Thanks for your trouble.My son was able to fix it.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Epson Master
  • 1,362 Answers
Double check your printer settins:
File - Print - (does your printer show and is highlighted? )
if No, right clik and set as default
go to Properties and send test page, no result ?
reload driver from Hp website.
Posted on Jul 16, 2008
  • CheckitRight
    CheckitRight Jul 16, 2008
    Sorry meant Epson website
HP LaserJet M5025 MFP scans too light. Under default job options, image adjustment, darkness set to 3. The printer was sent to us upside down. We recently installed a brand new cartridge. Any suggestions?
If you print the configuration pages from the administration>information menu and they look dark then you know that the printing system is working fine. If they are light as well, then it is possible that being shipped upside down resulted in some dirt getting into the laser scanner. The image original settings are kind of wonky, in that it is backwards to normal assumptions. Darkness refers to the actual orignal you are scanning, so in most cases if you have lighter origjnals then you need to set darkness lower. As well, check whether the image type is set for photo or text. Setting for text will result in darker scans.
Jun 18, 2011 | HP LaserJet M5025 MFP Printer
COMMUNICATION ERROR, DOCUMENT SCANS, AND GET ERROR
well i don't know a lot about printers, but i'd suggest to renew its drivers and if that doesn't work then reinstall windows
Sep 28, 2010 | Panasonic KX-MB781 All-In-One Laser...
The printer works fine. Scans and copies streaky.
I have the same printer, Its just needs cleaning. Go to problem solver inside menu and follow the instructions
Jul 26, 2010 | Epson WorkForce 600 All-In-One InkJet...
The printer works fine. Why do the scans and
It means the scanning assembly has gone out, either the lamp is bad or the sensors, you can check at
www.partsurfer.hp.com and see if they have a replacement scanner, but I doubt you can replace it.
Jan 14, 2010 | HP LaserJet 3015 All-In-One Printer
Dell 962 prints fine - copies, scans and faxes are illegible
That is a sound approach you offer because, 1.) Cleaning the Carts. usually solves streaking, 2.) Cleaning the strip on the read glass fixes lines on the scanned images, 3.) You may have a saturation of ink inside the conveyance rollers that is soaking everything. You don't want to know how hard it is to get all the ink out of a wet printer. Replace it, save the hassle.
Jul 15, 2009 | Dell 924 All-in-One InkJet Printer
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Brother Scanner, scans the page but prints black and vertical
I called technical support for this issue previously with my brother mfc. It would only do this during color scanning. b&w scanning was just fine. The tech support put me through resetting the reference point of the scanner through a series of button pressing and closing and opening the paper feeder. I kept gettting the same lousy results. Then they determined that the scanner module needs replacing and I needed to take to the nearest service center.
Dec 23, 2008 | Brother MFC-8640D Printer
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Won't print but copies and scans
What operating system and is this on a network as a shared printer or wireless?
Download Epson net config from the website and run the program on all computer and configure it, make sure on the printer that ip is set to obtain automatically.
try this link as well
http://files.support.epson.com/htmldocs/cx11nf/cx11nfug/dwnh_7.htm
Jan 16, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
