2004 Chevrolet Avalanche Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Approximately how long does it
Anonymous
Level 3:
President:
  • Master 1,190 Answers
  • Posted on Jan 21, 2011
Anonymous
Master
Level 3:
President:
Answers
1190
Questions
0
Helped
487600
Points
3636
Hello: Approximately 2 - 4 hours depending on the ability and experience of the technician performing the task. There are two sensors, both should be replaced. The intake manifold has to be removed to replace the knock sensors.
2helpful
Radiator fans not working on a 99 dodge Grand Caravan
Hi there:
The engine coolant temperature sensor is a variable resistor with a range of -40 degrees F-265 degrees F (-5 degrees C-129 degrees C).
The engine coolant temperature sensor provides an input voltage to the PCM. As the coolant temperature varies, the sensor resistance changes resulting in a different input voltage to the PCM.
When the engine is cold, the PCM will demand slightly richer air/fuel mixtures and higher idle speeds until normal operating temperatures are reached.
The engine coolant temperature sensor is also utilized for control of the cooling fan.
Fig. 1: Engine coolant temperature sensor location - 3.3L and 3.8L engines
Check this test procedure:
  1. Turn the ignition switch to the OFF position.
  2. Detach the coolant temperature sensor electrical connector.
  3. Using a DVOM set to the ohms scale, connect one lead to terminal A and the other lead to terminal B of the coolant temperature sensor connector.
  1. With the engine at normal operating temperature, approximaterly 200 degrees F (93 degrees C), the ohmmeter should read approximately 700-1000 ohms.
  2. With the engine at room temperature, approximately 70 degrees F (21 degrees C), the ohmmeter should read approximately 7000-13,000 ohms.
  3. If not within specifications, replace the engine coolant temperature sensor.
  4. Test the resistance of the wiring harness between PCM terminal 26 and the sensor wiring harness connector. Also check for continuity between PCM connector terminal 43 and the sensor wiring harness connector. If the resistance measures greater than 1 ohm, repair the wiring harness as necessary.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Where is the thorttleposition sensor on 2001jeep cherokee
The 3 wire Throttle Position Sensor (TPS) is mounted on the throttle body and is connected to the throttle blade.
The TPS is a 3wire variable resistor that provides the Powertrain Control Module (PCM) with an input signal (voltage) that represents the throttle blade position of the throttle body. The sensor is connected to the throttle blade shaft. As the position of the throttle blade changes, the resistance (output voltage) of the TPS changes.
The PCM supplies approximately 5 volts to the TPS. The TPS output voltage (input signal to the PCM) represents the throttle blade position. The PCM receives an input signal voltage from the TPS. This will vary in an approximate range of from .26 volts at minimum throttle opening (idle), to 4.49 volts at wide-open throttle. Along with inputs from other sensors, the PCM uses the TPS input to determine current engine operating conditions. In response to engine operating conditions, the PCM will adjust fuel injector pulse width and ignition timing.
The PCM needs to identify the actions and position of the throttle blade at all times. This information is needed to assist in performing the following calculations:
Cherokee, Grand Cherokee, 1999-2005
Print
Operation
Ignition timing advance Fuel injection pulse-width Idle (learned value or minimum TPS) Off-idle (0.06 volt) Wide Open Throttle (WOT) open loop (2.608 volts above learned idle voltage) Deceleration fuel lean out Fuel cutoff during cranking at WOT (2.608 volts above learned idle voltage) A/C WOT cutoff (certain automatic transmissions only)
Removal & Installation
3.7L & 4.0L
  1. Disconnect TPS electrical connector.
  2. Remove TPS mounting screws.
  3. Remove TPS.
To Install:
The TPS is mounted to the throttle body. The throttle shaft end of throttle body slides into a socket in the TPS. The TPS must be installed so that it can be rotated a few degrees. (If sensor will not rotate, install sensor with throttle shaft on other side of socket tangs). The TPS will be under slight tension when rotated.
  1. Install TPS and retaining screws.
  2. Tighten screws to 7 Nm (60 inch lbs.) torque.
  3. Connect TPS electrical connector to TPS.
  4. Manually operate throttle (by hand) to check for any TPS binding before starting engine.
4.7L
  1. Remove air duct and air resonator box at throttle body.
  2. Disconnect TPS electrical connector.
  3. Remove two TPS mounting bolts (screws).
  4. Remove TPS from throttle body.
To Install:
The throttle shaft end of throttle body slides into a socket in TPS. The TPS must be installed so that it can be rotated a few degrees. If sensor will not rotate, install sensor with throttle shaft on other side of socket tangs. The TPS will be under slight tension when rotated.
  1. Install TPS and two retaining bolts.
  2. Tighten bolts to 7 Nm (60 inch lbs.) torque.
  3. Manually operate throttle control lever by hand to check for any binding of TPS.
  4. Connect TPS electrical connector to TPS.
  5. Install air duct/air box to throttle body.
Hope this helps
I bought a 2004 PT Cruiser today at an auction. I was driving it home & reailzed that it wasn't shifting gears. I put it in 1st then to 3 to test it & it wouldn't shift. Whatever gear its...
First thing's first. Any time you see a low system voltage code you need to check for proper battery voltage and charging system operation. If the transmission controller isn't getting at least 12 volts, nothing in the transmission will operate properly.
If the alternator is working and no electrical problems are found, check all fuses and fusible links. Also, check for corrosion in the fuse box under the hood.
You will need an additional scan tool to read codes and data from the transmission controller. If you don't have access to one, it would be wise at this point to take the car in. Beyond this point it will be far more time-consuming and expensive to start guessing and throwing parts at the car.
The most likely culprate on the fluid pressure sensor code low system pressure caused by internal transmission wear or damage. A transmission problem is probably why the car went to auction in the first place.
Location of knox sensor
HI, they are located under intake manifold.
The first sensor is located in the front of the engine and the second sensor is located in the back of the engine. Remember to replace the intake gaskets once you replace the sensor/s.
Trying to replace the knox sensor but i cant locate it in the engine
the knock sensor is located under the intake manifold in the cavity between the two engine banks. be sure to apply a layer of silicone or some sealant around the sensor after installing, this will keep water from gathering around it causing it to fail again.
2helpful
Replaceing the knox sensor
Do you mean knock sensor? well, it's located below intake manifold
2helpful
2answers
Have been told 'knox' sensor's need replacement @
The "knock sensor" adjusts timing. So bent valves could result if timing is way off. Your car would quit running before timing was that far off. $700 sounds high shop around.
1991 chevy S 10 EST not working
Check out the Knox sensor & or the Blue wire going to it if it is Grounded , the timing will not Advance, Knox sensor is there to detect knock then it grounds if it catches a Knock to Prevent
Pre Ignition Ping-SPARK KNOCK-
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
