Question about Lexmark P4350 All-In-One InkJet Printer
Carrier Jam I have a lexmark 6200 series. Just changed my ink catridges and this is the message am getting "Clear carrier jam" alongside a cranking noise. The catridges are no longer moving when u open the top. i have a erroe message on the screen and it says "clear carrier jam" but when i had a look inside i noticed a clear strip of plastic had come off inside and dont know where it came from
  • 2 more comments
  • reomsw Aug 26, 2008
    Ive had the same problem with lexmark p4350
  • Jinna Jacobs
    Jinna Jacobs Nov 14, 2008
    I am also having the same problem with the p4350 & I have no idea were this clear plastic strip goes???
  • Anonymous Dec 19, 2008
    I have the same problem, I dissasembled the printer and replaced the plastic strip but as soon as I turned the printer back on the strip fell off. When I line up the strip the holes are not small enough to stay on the post. Do I need a new strip or is there another way to fix this problem
  • sehall29 Dec 19, 2008
    I also have a problem with the Lexmark P4350 printer. I already took the thing apart and put the plastic strip back in place, when i turned the printer back on the strip fell off again. When I lined up the strip on the posts I noticed that the holes in the strip were to big. I belive I had the strip in the back of the carrier properly. If anyone can help please let me know
THis solution I copied from another post. It worked for me as well
First you need to open the printer. Unplug from power. Then lift the scanning device, you can partially remove it when pushing the "hooks" close to where the lid is connected (careful with the cable connections). Then remove three screws in the cover of the bottom part and with some fiddling around you can remove the cover. Again be careful with the cable connections. Of course don't do it if you are worried about warranty or breaking the printer.
The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging.
Posted on Dec 18, 2008
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
Carrier Jam message in window
Jul 21, 2012 | Lexmark X4650 InkJet Printer
Carrier jam
From what you are saying you are getting 'clear carrier jam' because of a misalignment. The jam error message is a generic message that applies to a multitude of things. The carrier while is in right, might not be sitting right. A piece of plastic that holds the carrier might be broken or the printhead might be messed up. Anything that causes it to not sit the way it wants will cause that error message.
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Carrier Jam(lexmark x5320)
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a carrier Jam!? It a lexmark x5320 I have tryed everything nothing works.
In this case unplug the Power Supply from the Printer...............
Take Out both the catridges from the Printer.................
Move the Catridge Carrier which holds the Catridges inside the Printer from left to right and from right to left for about 20 Times.......................
now insert both the catridges inside the Printer and Plug in the Power Supply and see whether you get the error message again.................
If u still have that error message please Call lexmark:
1-800-LEXMARK (539-6275)
Just call this number because the Enchoder strip has to be replaced........
Good Luck
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark P4350 All-In-One InkJet Printer Logo
170 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
