Question about HP Officejet 5610 All-In-One InkJet Printer
MajicJack and faxing
Sometimes faxing works and sometimes not. Sometimes only have the page gets transmitted. Any ideas on this and a fix? -AMBERY
  • jimstap Jan 10, 2009
    My problem is a little different. I just set up a new Majicjack and it works great for sending faxes. It also works great for receiving faxes if I lift up the receiver upon receiving a fax and I press the fax receipt button. The problem is when a fax is sent, and I want the machine to receive the fax automatically. When testing the automatic mode, I received 1 fax out of 5 tries. The other four tries acted like the fax was about to receive, and then it disconnected.
    I have a Panasonic KX-FP145 fax machine. Majicjack tells me to slow down the fax machine and turn off error correction. The specs on the fax machine shows that the machine can run and various modem speeds, but provides absolutely no information on how to adjust to these speeds. There is no information whatsoever concerning error correction.
    If I use my normal home phone system with this fax machine, it never fails. Please help. Thanks.
    Novelist:
  • 150 Answers
1) I suspect a bad telephone connection, or connections are
being dropped.
2) Check the phone line wire. Unplug the phone line from the
fax machine, and plug it into an ordinary phone. Call a few
friends and check that the phone-line and the cable is
working. Make sure the line does not sound noisy, crackly
or drop out entirely. Jiggle the cable connectors as you do
this.
3) If the phone line is OK, then try faxing several different
numbers with a test message, to make sure that the problem
is not unique to a single destination, which would be a fault
at the receiving end.
4) If the phone line is good, and the all destinations are bad,
then the fax unit is defective.
5) If the problem happens during receiving only, make sure
you are not out of ink or toner, and that the paper is not
getting jammed.
Good luck, please rate my answers
Martin
Posted on Jul 16, 2008
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
Kyocera KM-3050 - Faxing error code
Try calling that number from a regular phone and listen for fax tones...it may not be a fax number.
Oct 15, 2009 | Kyocera Office Equipment & Supplies
Get communication problems when sending some faxes - when sending faxes to some places it won't transmit but will transmit to other places
The problem can be either a error with your phone service or an incompatablity with your machine and the receivers.
Sometimes the problem is as simple as the receiver's machine being set to receive on more rings than your's before it goes into redial.
Apr 15, 2009 | Office Equipment & Supplies
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Prints only 1/2 the page
There is a conflict with the Window's spooler. Here is how you fix it.
Go to the printers and faxes area and RIGHT CLICK" the printer and select properties.
Select the ADVANCE tab at the top.
Click "PRINT DIRECTLY TO PRINTER" and then "APPLY."
You are good to go..
Jun 23, 2008 | Epson Stylus Photo R260 InkJet Printer
Call Sevice 4
reset the unit..press menu#9000*550 Then press start.Call service 3 has something to do with the temperature of the unit check thermostat @ the fuser unit.replace it because the thermostat is not switching to on/off condition although it reaches its peak temperature.
Mar 17, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
How to clear Memory in Sharp UXP115
FIRST:1-PRESS START/MEMORY KEY IF YOU WANT TO TRANSMIT THE PAGES WHICH STORED UP TO THAT POINT IN MEMORY THE REMAINING PAGES WILL BE REJECTED FROM THE FEEDER.AFTER TANSMISSION THE MEMORY WILL BE CLEAREED.AND YOU CAN TRANSMIT THE REMAINING PAGES.YOU NEED ALSO TO TRANSMIT THE PAGE WHICH WAS BEING SCANNED WHEN THE MEMORY FILLED UP.
PRESS STOP IF YOU WANT TO CANCEL THE TRANSMISSION.
Feb 20, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
Out-going Fax fails to complete (Canon LC 2050P)
Two things: Can you make a copy without this happening? And, Does this happen with certain specific fax number or randomly?
Jun 22, 2007 | Canon LaserClass 2050 Plain Paper Fax
HP Officejet 5610 All-In-One InkJet Printer Logo
506 people viewed this question
Ben Johnson
