Question about Philips CCC132AT 13 in. TV/VCR Combo
Turns off!! My tv turns off by its self.I turn it back on but then it turns right back off in 1 minute.What can I do to fix this.
    Sergeant:
  • 395 Answers
More than likely the VCR load mechanism has a problem it may be out of sync or the load sensor LED inside the mechanism has failed (most common problem). a tech should repair this.
Posted on Jul 16, 2008
How to fix my lg tv
if it is a samsung tv, mine blew two cheap capacitors and cost under £1 to fix with a soldering iron and a bit of solder wire
Aug 29, 2016 | LG 50" 4500 Series Plasma HDTV - 50PN4500
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
Toshiba 27af45 turns off by itself every 15 minutes..how do I fix
I think the timer setting in your TV is broken. Try fixing this.
May 07, 2009 | Toshiba 27AF45 27" TV
Tv turns t"s self off,take 20 minutes to get back on
Check the "sleep timer" function and make sure that it is not turned on (if it has one) - one other thing I would try is to be sure that an energy saving feature is not enabled that puts your TV on standby after a period of time (although this is unlikely).
Feb 01, 2009 | RCA HD52W59 HDTV Projection Television
it's your remote flipping out or the power supply is bad.
Jan 28, 2009 | Soyo DYLTO32A 32 in. HD-Ready LCD...
Mitsubishi WS 65513 turns itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Tv turns off by it self
Ours 60" (60P8342) turns off after a short period of time also. My husband researched it online. The cheap solution he was told to try is to unplug the TV (or plug into power strip and switch off) when you are done watching it. A computer board inside over heats and it's a protection mechanism for it to turn off. Otherwise, it's over $100 to fix the computer board.
May 29, 2008 | Philips 60P8342 60" Rear Projection...
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Tv turns self off when turned on
I have a magnavox vhs and dvd television that started turning itself off when turned on. what could be the problem?
Nov 21, 2007 | RCA TruFlat 27F520T 27" TV
Philips CCC132AT 13 in. TV/VCR Combo Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
