Televison & Video Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Definetion of proton - Televison & Video
Anonymous
Level 3:
President:
  • Master 2,080 Answers
  • Posted on Jan 21, 2011
Anonymous
Master
Level 3:
President:
Answers
2080
Questions
Helped
927584
Points
6465
Positively charged particle inside the nucleus of an atom.
1helpful
I need a manual for Proton D940 receiver. I lost mine. Where can I find one?
There are a few options you can try to find a manual for your Proton D940 receiver:
  1. Check the manufacturer's website. Proton may have a copy of the manual available for download on their website.
  2. Contact the manufacturer. Proton may be able to send you a copy of the manual or point you to a location where you can find one.
  3. Check online retailers or auction sites. There may be copies of the manual available for purchase from online retailers or on auction sites such as eBay.
  4. Check with a local repair shop or electronics store. They may have copies of the manual or be able to help you find one.
  5. Check online forums or discussion groups. There may be other users of the Proton D940 receiver who have a copy of the manual and would be willing to share it with you.
I hope this information is helpful. Good luck in finding a manual for your Proton D940 receiver.
2answers
Proton gen2 1600cc timing belt replacement guide
How to set Proton gen 2 fire Oder and crank shaf setting please help and guide me please
1helpful
Where can I get a proton impian 04 manual from
The best place to get hold of a proton service manual is to download it from the website
http://www.repairservicemanuals.com/Proton
1helpful
How do you connect a proton d540 amplifier to a Marantz sr45 ?
Why? The Marantz receiver already has an amp and the Proton is an integrated amp. But if you want to use the Proton as a preamp with the Maranyz you could remove the jumpers on the back of the Proton then connect RCA cables from the Proton's Pre Out to the Marantz's Tape In but I really don't see why.
How are protons organized?
Atoms are the basic building blocks of everything around us. They come in different kinds, called elements, but each atom shares certain characteristics in common. All atoms have a dense central core called the atomic nucleus. Forming the nucleus are two kinds of particles: protons, which have a positive electrical charge, and neutrons, which have no charge. All atoms have at least one proton in their core, and the number of protons determines which kind of element an atom is. For example, an oxygen atom has 8 protons. If you were somehow able to change the proton number of this atom to 7, even if everything else remained the same, it would no longer be an oxygen atom, it would be nitrogen. For this reason, we list the different elements by their proton, or atomic, number. The periodic table of elements is a chart of all of the elements that have been discovered so far, in order by their atomic number.
FIRING ORDER PROTON JUMBUCK
If it's 4 cylinders, it's 1-3-4-2. for Mitsubishi/Proton engines.
The nucleus of an atom contains _________. a.
It contains "Protons and Neutrons" so the solution for your question is "C".
Good luck.
Thanks for using FixYa.
2answers
Which particle is the hightes in the following
Protons have a +1 charge. This is the same magnitude of an electron but an electron has a −1 charge. Neutrons have a 0 or no charge.
The following Wiki Article explains the process of Proton decay
Main article: Proton decay Protons are observed to be stable and their theoretical minimum half-life is 1036 years. Grand unified theories generally predict that proton decay should take place, although experiments so far have only resulted in a lower limit of 1035 years for the proton's lifetime. In other words, proton decay has never been witnessed and the experimental lower bound on the mean proton lifetime (2.1×1029 years) is put by the Sudbury Neutrino Observatory.[5]
However, protons are known to transform into neutrons through the process of electron capture. "When a high energy-proton collides with an atom, it causes the ejection of an electron from the outer layer of the atom."[6]:125 This process does not occur spontaneously but only when energy is supplied. The equation is:
1a11b43084f71df3683387ac7281c27b.png where
p is a proton, e is an electron, n is a neutron, and νe is an electron neutrino The process is reversible: neutrons can convert back to protons through beta decay, a common form of radioactive decay. In fact, a free neutron decays this way with a mean lifetime of about 15 minutes.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
