Question about Sony STR-DG510 Receiver
Won't work. Won't turn on. Click sound when the power button is pushed but nothing more. No lights on. Nothing at all. Only 3 months old purchased at Future Shop 4 hrs from my home. Thanks Jackie Healy RR 2 Lions Head, Ontario
    Sergeant:
  • 395 Answers
Call sony for warranty repair. there is an internal problem most likely one of the amplifiers has shorted and is in protect mode.
Posted on Jul 16, 2008
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
1982 Suzuki GS 650GL won't start. I've purchased a
Well the good news is the click indicates the switch is working, when you press the switch the 2poles on the solenoide are joined together alowing the current to the starter,bridge the wires at the solenoide this should put power directly to the starter you wont need to press the start switch, if the engine does not turn over check the connections to both the battery and starter motor,
Jul 25, 2011 | 1982 Suzuki Gs 550 L
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Scooba won't turn on
It sounds like you've got a finicky power button. Not a lot that can be done about that, but you may want to try getting your hands on the old-style Roomba remote, the black one. The power button from that will power on a Scooba, though you can't start a cleaning cycle that way. This might allow you to bypass the Scooba's power button altogether.
May 08, 2009 | iRobot 5800 Scooba Vacuum
Insignia NS-32LCD will not turn on.
WIth the set only 7 months old, it should still be under warranty. The problem now is that by opening it up, you effectively have voided the warranty. That being said, the problem is that a problem has been detected internally and the set shuts down to prevent further damage. The first suspect is the main power supply board. I would try for warranty service first. If that is not available a local service shop should be able to take some measurements inside to detemine whether the power supply is not working correctly or if the suply is being told to shutdown. WIth what little info is available here and not being able to examine the actual unit, remote diagnosis will be difficult.
Keep us posted.
Dan
Aug 25, 2008 | Televison & Video
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Sony STR-DG510 Receiver Logo
79 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
