CERTIFIED TV EXPERT HERE, follow this information I provided 3 long solutions to this issue/s
Solution 1
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The firstlink below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution.
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Turn the car on then hold the "Clock" button until the ":" begins blinking -- usually four to six seconds though some take up to a minute.
